Question about Symphonic Televison & Video
I DO NOT HAVE THE ORIGINAL REMOTE. THE TV IS CONNECTED TO A SATELITE FEED. AFTER A FEW SECONDS ON SOME CHANNELS THE SCREEN GOES BLANK AND A MESSAGE COMES ON "PROTECTED TV PG-14" IS AN EXAMPLE. HOW DO I CORRECT THIS PROBLEM? SYMPHONIC TELEVISION
  • 4 Answers
Walmart sells a ge universal remote in the check out it is a three in one remote. for five bucks. it does everything i own. except a twenty five year old tv. it will even access the menus on my ac unit.
check it out. you may have to use the manual program mode on the thing but it will probaly work
Posted on Mar 12, 2009
I have did the auto scan and the tv screen is still blank. i need some answers asap please!!!!!!!!!!
does a DVD player work on the unit?
if so, be sure you have good connections of your input cables (and you know these connector cables to be good), then see if you can manually program channel 3, or any other channels programmed manually. I suggest channel 3 in case you are using satelite or cable box. Then turn the cable or satelite box & see if you get reception on channel 3.
Apr 01, 2014 | Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
I'm not sure if this is a TV problem or a satelite problem. We removed the HDMI cable from our 32' Dynex flatscreen for a few minutes, re-connected it and now the TV says "Perform Channel Auto...
Seu problema parece ser do receptor de sinais via satelite. Programa?ao de canais no receptor de satelite; Verifique se seu cartao (chip card) esta bem conectado.
Dec 13, 2010 | Dynex Televison & Video
The tv is connected to Dish Network as TV2. I accidentally changed the channel & now I can't get it back to channel 90 - it only goes to 13 now. How do I fix this?
In the menu screen, you must find antenna connections. For example " TV Air "(over the air channels 2 through 13) or cable TV. You must tell the menu to select cable TV (with the original remote). This will allow you access to channel 90. Thanks for asking and show a few hands of support.
Nov 07, 2010 | Orion STV2763 27" TV
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
TV Stuck in TV Guide Plus+ Installation Mode
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Feb 15, 2007 | Haier HTF20R21 20" TV
Televison & Video Logo
242 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
