Question about Nautilus Bowflex series 5 treadmill
Error sys 15
Lately I get error sys 15 on my treadmill, this can occur even when I am not using the unit, there will be nothing displayed on the control panel, then suddenly the error appears and the unit beeps, also occurs when I am using it, I checked the speed sensor, seems OK, also the buttons will not work as well sometimes, Ie cannot increase speed or change elevation
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
Tip
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph
B) User is pushing against treadmill belt causing it to go faster than the set speed
C) Defective lower board or misaligned speed sensor
D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed.
B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt.
C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board.
D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
on Apr 10, 2015 | Landice Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Precor Treadmill C956 error 21
Precor Error Code 21 Error Code: 21 Manufacturer: Precor
Model: All Models
Error Description: Error 21, Too many Consecutive Power Requests- The error 21 observes a treadmill's power bit reading when the treadmill was operating at speeds above 1 mph. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 21 indicates that at a speed greater than 1 mph, an excessive amount of power is being demanded from the motor controller. Possible Reason:
  1. A badly worn deck and/or running belt can cause the error to appear when the unit is in use.
  2. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the unit is in use. The unit may also slow down or become sluggish when the load or speed is increased.
  3. A jumper may be required on the lower PCA if installed into a 120 VAC (Version 2) treadmill.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a know good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  2. Inspect and repalce both drive motor brushes if necessary.
  3. Inspect the lower PCA (if unit is 120 VAC/ Version 2) for jumper. If jumper is not installed, error typically appears between 7 mph & 8 mph. Install jumper if necessary. CAUTION - DO NOT install jumper if unit is 240 VAC. Installing the jumper on a 240 VAC unit will casue the lower PCA to fail.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Dec 08, 2013 | Precor C956 Treadmill with Cardio Theater...
I have a VL0901 treadmill that displays error 9 when I turn it on. How do you clear this as nothing works.
follow this troubleshooting and fix it. God bless you
Error 09, Lower PCA Memory Test Error
Probable Cause Most commonly indicates a problem with the lower PCA when the error consistently appears. It is rare for a failure to occur that would cause this error.
Corrective Action
  • The lower PCA should be replaced if the error consitently appears at power up.
    1. External causes may make the error appear intermittently.
      1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
      2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittent
    Jul 29, 2013 | Exercise & Fitness
    Error code 1 and 3 on my Precor 9.21s treadmill?
    Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
    Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
    Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
    Precor Error Code 03 E03 EEPROM Test Error
    Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
    My control panel on the Sole F80 Treadmill lights up but nothing I press works
    adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
    tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
    God bless you
    Jul 22, 2012 | RTO Sole F80 Treadmill
    My horizon treadmill immediately stops after 2 seconds
    StarTrac 4500 Treadmill NO RPM Error Probable Cause A) Damaged or misaligned RPM sensor
    B) Display Cable
    C) MCB
    D) Filter Network
    Corrective Action A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
    C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
    D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
    Star Trac 4500 Treadmill NO RPM Error Code
    Jun 28, 2012 | Startrac Fitness Products Exercise &...
    Life Fitness Treadmill "FET" error
    Can you please provide model of unit.
    Feb 20, 2010 | Exercise & Fitness
    Exercise & Fitness Logo
    Top Nautilus Exercise & Fitness Experts
    David Payne
    David Payne
    Electro Med Services...
    Techmotionusa.com
    Techmotionusa.com
    Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
