Question about Vehicle Parts & Accessories
Power steering failure
New power steering pump whining noise.
  • 463 Answers
There still could be air in steering box. Hold wheel all the way to left and hold for 1 min then all the way to right for one min the system should now have purged all air out. Does sometimes need to be drove to work rest of air out.
Posted on Apr 24, 2013
  • Aaron Moore
    Aaron Moore Apr 25, 2013
    Thanks. It is a bit quieter but did not fix the steering issue. Might be the steering gearbox
Leeking power steering flooded
hi robin.
The first sign of fluid leaking from the power steering is a pump whine, because the fluid is low, the pump will start to make a whine noise, especially when turning the steering wheel.
If you think you may have a car power steering leak, the first thing you should do is check the power steering fluid reservoir, if the fluid level in the reservoir is low, you just might have a leak in the power steering system.
Power steering fluid has a very distinctive smell, it smells like a burnt marshmallow, that is my opinion on the smell, and I'm sure you will not find that documented anywhere on the internet or any repair manual.
If you feel the steering in your vehicle binding up, or the power steering pump starting to make whine noise, it's a good sign your power steering fluid level is getting low or it's empty. Running the power steering pump with low or no fluid could be very damaging to the entire power steering system because metal particles from the pump enter the system and cause internal failure of the steering rack and to its valve body or to the steering gear box.
Nov 06, 2017 | Cars & Trucks
Whining power steering pump on 2001 bmw 740il
have you put a different type of power steering fluid?
in some instance, if they put a different type of fluid, the solution bubbles up and makes a whining noise when you use the car.
tnx 4 using fixya,
drcool
Oct 10, 2008 | 2000 BMW 7 Series
Tip
Power Steering Pump Noise
As you turn your steering wheel it is this fluid pressure that aids in turning the wheels of your car. ... If the pump impeller is trying to move power steering fluid and starts catching air bubbles it can cause whining noises and vibrations to occur.
Maybe you've heard it at a stop light. Maybe you've heard it as you pass a car on the freeway. Or maybe you've heard it in the parking lot at work when someone is leaving. The unmistakable whine of a power steering pump can make even the most confident mechanic wonder when that car will breakdown.
Power steering pump noise is a unique noise that your car may make and once you've heard it you always know what it is. The noise is a mix of a whirring and a whining and will always vary with the speed of your engine whether your car is driving or in park. This whining noise can be subtle or extremely loud and may be worse in colder weather, or right when you first start your car.
Power steering pumps are most often vain style centrifugal pumps that are tasked with pressurizing the power steering fluid and pushing it down to your power steering gear or rack. As you turn your steering wheel it is this fluid pressure that aids in turning the wheels of your car.
There are a few reasons why you are hearing power steering pump noise from your car. First, it may simply be due to the design of the pump. Sometimes, noisy power steering pumps can continue to work flawlessly for years after they start making noise. This may simply be due to the manufacture's design or a tight tolerance in that particular pump. In this case, you would hear the noise but not see any other adverse effect like a loss in power steering, leaking fluid or a wobbly pulley. In this case, you may be able to help reduce your power steering pump noise by choosing a different type of power steering fluid, like a synthetic fluid.
Your power steering pump may also be making noises due to air trapped in the system. If the pump impeller is trying to move power steering fluid and starts catching air bubbles it can cause whining noises and vibrations to occur. Even tiny air bubbles you cannot see that are trapping in the power steering fluid may be causing the whining you are hearing. In this case, the best thing to do is flush your power steering system to try and remove the air from the system. Having air trapped in your power steering system can be difficult to diagnose so you may need to simply try a power steering flush to see if it solves your problem.
Power Steering pump noise may also be due to a failing power steering pump. As the bearings on the impeller go bad it will start to make noise as the pump is turning. If you have a bad power steering pump you usually will also experience leaks from around the pulley, a wobbly pulley, or difficulty turning the steering wheel when you are stopped. If you have multiple of these symptoms together, it is probably time to replace your power steering pump.
Lastly, and most usually, a whining power steering pump is an indication of a low fluid level. Your power steering fluid is probably something you have rarely if ever checked, so it often comes as a surprise if the level is low. Your power steering fluid reservoir is also relatively small so even a slow leak will cause a low fluid level relatively quickly. To confirm this is your problem it is as simple as checking your power steering fluid level. Some power steering reservoirs are clear so you can see through them to check how full they are. You may have to wipe away some dirt and grime to find the "full" line, but it should be easy to check. If you have an opaque power steering fluid reservoir there should be a small dipstick under the cap that will help you measure the fluid level. If it is low, then you have a leak somewhere and topping off the fluid should quite down your power steering pump.
If you discover a power steering leak, rather than simply continuing to add fluid every time it gets low, you should fix the problem permanently so you don't have to continue to check your power steering fluid level. Replacing lines or seals can be a surprisingly difficult task due to the location of your power steering pump and steering gear or rack. The easiest way to seal your leak is to do it from the inside out!
try this link out for more power steering problems.
Power steering whining sqreeching Google Search
on Dec 14, 2017 | Cars & Trucks
Can altenator sound like bad power steering pump?
Many new power steering pumps will exhibit a whining noise for a time after installation. Some won't. Typically, they quiet down within 2-3 weeks once they break in a bit. If the new pump is doing its job and not leaking and the whine is not more like an ear-splitting shriek, just wait it out and see what happens.
Feb 19, 2016 | Cars & Trucks
Whining sound when turning
Please elaborate. Does it happen when stopped and turning the steering wheel, at certain speeds or both?
Does yours have power steering? That was an option for 1990.
First thing that comes to mind is the power steering pump or just low on fluid. Check the fluid level first. Not necessarily in danger of imminent failure but if yours has never been replaced it would be a good idea to get a new one for peace of mind.
One way to check it is to go to drive into a big empty parking lot, turn off the engine (don't turn the key too far as to lock the steering) and make some of the same kinds of turns that typically makes the noise happen. If it still makes the same noise it's NOT the power steering pump and I'm at a loss without more details. If it doesn't whine, then it still could be something with the power steering. With the car running and parked have someone turn the steering wheel back and forth and listen for it under the hood and you should be able to find the source. If you don't know where the power steering pump is I'd suggest getting a service manual. I recommend one from Haynes.
Oct 31, 2013 | 1990 Mazda MX-5
Power steering fluid leaking and there is a whining noise along with a rattling sound on my 2000 Nissan Maxima.
Doesn't matter you have a leak
You should have stopped using it
when you first noticed the leak & had
it resolved,now you may need a new pump
Oct 08, 2012 | 2000 Nissan Maxima
Whining noise while engine is revving/accelerating
check power steering pump fluid, with engine off try to wiggle every pulley if any move at all that's your culprit, power steering, alternator, idler puller, water pump, but sounds like bearing failure
Jun 08, 2012 | 2006 Hyundai Getz 1.4
Power steering whining, sqreeching
hi Eva.
or check this link out for more info on this matter.
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Vehicle Parts & Accessories Logo
88 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
