Question about Audio Technica Audio Players & Recorders
Audio not playing
Not playing
  • Audio Technica Master
  • 5,056 Answers
You need to give a bit more information such as how the deck is connected.
Posted on May 19, 2013
Compaq cant play audio sound
go to support.dell.com and enter model number then get new set of audio drivers
report on results from solution 1
Jun 16, 2012 | Dell Computers & Internet
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
Dear sir, i have compaq presario cq40-330tu laptop.i want to play audio in my laptop by using windows xp
...please check your audio driver of your computer if install already or check your audio player if this player can play the audio format that u played...if not install, try to install first before you can play an audio files...or install a audio player that can play the audio format that you have...
Mar 02, 2011 | Computers & Internet
Video is not playing with audio
the bit rate of audio is high thats why audio not support while playing video, use normal bit rate video or audio , u can convert your fav video and audio through your pc
Apr 11, 2010 | Samsung Star GT-S5233 Cell Phone
Video is fine; audio will not play. All cables
Disconnect the cable from the ps3, the one that connects the ps3 and the monitor, for a few seconds, then reconnect it. You do this while video is playing or when you play games.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
When I play a video I have no sound.
Does it happen only when you play Video files or is it same in the case of Audio files... considering both the options: In case if you can't here any audio [while playing audio and video files] go to control panel--sound,speech and audio devices and audio devices--sounds and audio devices...make sure mute is unchecked and the device volume is not minimum.OR download the audio drivers from herehttp://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3687780〈=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=321957&prodSeriesId=3687777
by selecting language and Operating system.
second option where you can't hear the audio while playing the video files only...this is the case of either a missing codec or some option in the Video player.I suggest you to use VLC player http://www.videolan.org/vlc/ for playing a lot of formats. or either tell me which player are you using...I could give you a codec link or sort out any option that is preventing you from hearing any audio.
Aug 29, 2009 | HP Compaq 6730b Notebook PC
Ulead audio playing problem
By haneef_a on Aug 04, 2009
I can't play my project. I get this message:
Failed to use Direct Show video engine. Can not play back the audio stream: no audio
hardware is available' or the hardware is not responding. (13102:2:4)
Aug 04, 2009 | Ulead Videostudio 8 for PC
CD player can't play recorded audio cd's
That sounds right, some of your cd players will not be able to play recorded cd's . It's lame, but that's the way it is. Sorry.
Jun 17, 2009 | Audio Players & Recorders
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Coby mp-833
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
Aug 22, 2008 | Coby MP-C883 MP3 Player
37 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
