Question about New World G90m Gas Double Oven
Timer beeper very very quiet!
I need to have the hearing of a bat to hear this.
Is there a cure?
  • Paul Cox Mar 13, 2009
    New world g90m
  • Jyackle5
    Jyackle5 May 11, 2010
    make and model # please
There are 3 different tones. Press and release the minus button until you find one that suits.
Posted on Jun 10, 2009
My oven is cooking everything too quick and the flame does not turn down. I think the thermostat has gone, can anyone advise where I can buy a new one.
Posted on Apr 21, 2011
Model JTP15. Why did beeper on timer quit working?
The beeper failed from old age. Sixteen years is a lifetime + in the appliance business.
Mar 02, 2016 | GE Ovens
When buttons are pushed, no beeping. even when timer is set to go off, no signal that the time has expired
If all other functions are working and you just lost the beep sound then you have to make this choice. The beeper is actually mounted on the main control board. If it has gone bad--the only way to fix it is to replace the complete main control board which is an expensive part. One thing to check in your owners manual is if your control has a way to change the sound level of the beeper. If yes--it may have accidentally got shut off if it has that type settings.
Jun 16, 2015 | GE JTP75 Electric Double Oven
Timer very soft cannot hear it
Ive heard of this before. Many oven Manufacturers use clockwork timers which give 1 faint "ting" noise when finished. Others use electronic ones, which are not much better. If you are not standing next to the oven, you cant hear it. I usually recommend a separate timer , like a water timer or egg timer type thing which you can set (and Hear) and leave it near where you are working so you can go and turn the oven off. These can normally be purchased at Smiths, Tandys etc maybe Big W or K Mart
Apr 09, 2015 | Ovens
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Feb 26, 2015 | Whirlpool RBS305PDS Electric Single Oven
How to get over a problem with a quiet alarm
Just get over it, it's not important. Get a hearing aid. It's most likely your ears have aged and the alarm is just as loud as before. What?
It's also possible that the little noise maker has a hole to allow the sound out and has become clogged with dripping pizza, chicken fat, grease vapors, or because it's an electronic device in a hot box it may need replacing.
May 13, 2014 | Bosch HBN 7052 GB Stainless Steel Electric...
Some how I've turned the sound of my timer so quiet I can't hear it. How do I turn it up loud again, I lost my manual? :o( Angie
Without your model number this is an outright guess. Press menu, enter then settings until you see sound display then use the UP arrow to increase the volume and press enter again to save the settings. If you want a better answer I need your model number to better help you change the volume.
Thanks for choosing FixYa.
Kelly
Mar 25, 2011 | Ovens
I have a Hotpoint Double oven DQ471/2. The timer bleep is so quiet I cannot hear it and my partner who has a hearing difficulty finds it impossible. Our old New World oven had a bleep which was...
unfortunately there is no way of increasing volume of the bleep. its basically a simple beeper on the timer with no way of adjusting.
sorry cant be of much more help but what i will say is you should contact hotpoint about this problem as obviously is a design flaw.
Mar 18, 2011 | Hotpoint Ovens
The beeper on the stove timer came on for no reason at all, and I cannot get it to shut off for good. If I press timer, it will reset back to 1 hour and 59 minutes, but when it goes back to zero, the...
I would inspect the circuit board closely for a shorted component. If visually it appears normal it is likely the control board will have to be replaced. Eric
Aug 18, 2010 | Ovens
Jenn-Air Electric Oven - F-1 Code
You can disconnect the beeper so its not so annoying. turn oven off at breaker first. pull out oven a little so you can get at the top 2 screws on each side. The speaker is between the boards on the display module.
look for a red wire connected to a gold disc like speaker. remove this wire and you won't hear the beeping anymore.
Nov 27, 2007 | Jenn-Air JGW8130A Electric Single Oven
New World G90m Gas Double Oven Logo
327 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
