Question about Frigidaire ATF6000ES Front Load Washer
I have a front loader. Have had it for 3 years always worked just fine never a problem. It stopped when I was washing a front door mat and has yet to work since. It won't let any water in to fill and won't drain what's left in there. It's like the thing is clogged but I don't know what to do to unclog it? Please someone let me know what to do unclog it! Thanks!
  • 51 Answers
If the problem is just the pump being clogged,,, its very simple. Remove the back panel, or the front bottom panel (if your model has one) and locate the pump. Make sure ALL power is disconnected, and all electrical parts are covered because once you disconnect the tubing from the drum, and pump, all the water will be let out. If there is nothing clogging the tubing, you'll have to remove the drain pump and take a look inside.
Posted on Mar 13, 2009
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
We have a Whirlpool awm8143 model front loader. works fine
this could signify that you have the outlet hose to far down the outlet pipe of the machine, or if you have it plumbed in to the plumbing under the sink you could have dirty sink water flowing back into the machine
Mar 02, 2010 | Whirlpool AWM8143 Front Load Washer
I have the whirpool duet sport washer & dryer and everything I wash in the washer smells bad. The washer always smells not even washing with the pure bleach cycle works
Odors related to front loader washers is a common problem. The following link gives some pointers on things you may try to minimize odors and to keep them reoccurring:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Many of these tips are mentioned in the owner's manual of these washers. The most important factors inlcude:
1. Leaving the door open when not in use.
2. Checking for small garments that end up in the door bellow area.
3. Using HE detergent only.
4. Checking the drain pump reservoir for debris.
These simple factors will not only minimize odors, but will keep them from coming back. I personally own one of these front loaders and have never had an odor problem in the 9 years I've owned it by following this regiment.
If you have your doubts or have questions, please post back and let me know. I do hope you find this information helpful.
Mar 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
My Front End Load Washer does not drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Front loader locks, but nothing else. Please help!
ck to see if water still in tub if so remove as much as possible then remove bottom cover and clean pump..if you are washing baby clothes use mesh laundry bag for small items such as socks they tend to plug up pumps easily
Nov 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag Performa Washer
Whirlpool is good but Speed Queen is the best with the best warranty in the industry!
Tested to wash 8 loads a week for 25 years!
3 years parts and labor compared to all others with only 1 year! And 10 years for the transmission not 1 year like all the rest!
only 34 gallons of water used in the top loader and 13.9 gallons in the front loader.
I'm 53 and I'm not buying another washer again!
YES I SELL THEM AND EVERYONE WORKING IN MY STORE HAS ONE! There are plenty of more features!
Speed queen is used in laundry mats all over the world!
So now that I reallllly saved you, GIVE ME THE BEST RATING SCORE HERE AT FIXYA!!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 17, 2008 | Maytag Performa PAV2200
Hey, Buddy!
Well the mold is caused from the door being shut after you arte finished with the use of the machine. it traps the mouisture inside..To solve this use some bleach and water wipe it down around the door seal..then after each load just crack the door open this will allow air to dry out the inside and stop the mold
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
400 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
