Question about Dremel Multipro Model 395 Rotary Multi Tool Multitool 35000 Rpm
Dremel 395 manual
What is the equivalent new model. My model 395 just stopped working today, first it stopped low speed and then i kept using it until it stopped fully. I really like this model
SOURCE: Dremel 395 won't turn on
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Posted on May 27, 2008
SOURCE: obtaining a manual
dremel manuals are found here: http://www.dremel.com/en-us/CustomerService/ManualsAndLiterature/Pages/default.aspx
enjoy.
james
Posted on Sep 23, 2008
rowdy45176
  • 2176 Answers
SOURCE: The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
Posted on Jan 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Posted on Apr 14, 2009
apenning
SOURCE: My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Posted on Apr 17, 2010
Dremel 395 motor just stopped
if you cant afford a new one, and you are mechanically minded Id say why not give it a crack and open it up, could be something simple least it will give you some idea.
Sep 02, 2009 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 in the middle of drilling sea glass and the collet and bit stop turning while the motor is still running fine! GRRRRR Thanks for any suggestions!
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
Jun 17, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel model 395 went dead after a total of 25hrs use over 3years
Hello I am a woodworker also so I admire your project for your deaughter.
Your dremel 395 had a two year warranty. I would recommend that you get a new one or even a newly reconditioned one as the cost of the repair will be over 60 dollars. let me know what u decide to do......happy woodworking either way.
May 27, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Jan 29, 2009 | Dremel Variable - Speed Multipro Rotary...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Multipro Model 395 Rotary Multi Tool Multitool 35000 Rpm Logo
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
