Question about Health & Beauty
Conair hc318r How do you put the.spring on the moving arm.back
2 Suggested Answers
SOURCE: HOW TO PUT THE SPRING BACK IN A CONAIR HAIR HC318D
I can help with this!
Posted on Aug 07, 2009
Where can I get a spare spring for the arm of my curling Iron? I live in South Africa
no where unless from the manufacturer.they usually are made as a throw away item
Sep 01, 2016 | Conair BaByliss Pro Spring Curling Iron
The conair ww39 requires 2 batteries. When replacing what direction do they go?
Hello (revised)
Revision:
If the batteries stack on top of each other, they have to all go in the same direction. Be sure the flat backs are in the direction toward the spring. The protrusion on the other end of the battery will face away from the spring.
End revision.
It is very common to use the following method.
Look into the compartment and you will see a spring where each battery goes. Place the battery's flat bottom against the spring.
Put the compartment cover back on and test your scale. If the batteries are good and the scale works it should be ready for you to use once again.
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 25, 2016 | Conair Ww39 Digital Glass Chrome Scale
Where does the spring go on conair HC90RFD hair clippers
springs are used to apply pressure to the moving blade so the spring would go on the back of the blade under the screws
Nov 20, 2015 | Conair Health & Beauty
Mower deck draft arms keep coming loose from spring pins.
put a washer between the arm and pin,use a zip tie to hold them,put them on backwards,stop hitting things that will move them.
Jun 26, 2015 | Garden
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
How can i conair deluxe beard rechargeable beard & mustache trimmer
It sounds like it was taken apart by someone else???. Conair has a web-site which should give you diagram for putting it back together. Hopefully, all parts are there and undamaged.
Dec 07, 2014 | Conair Deluxe Rechargeable Beard &...
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Rear wiper rotates around
the wiper arm is held against the glass by a spring-corrosion in the arm doesn't allow the spring to pull it against the glass-in order to position it properly take the arm off,run the wiper while watching it-you need 2 people for this job-noting where it starts from and where it ends at. put the wiper where it looks close to where it should be and try it you may have to reposition it a few times. as far as the wiper arm being corroded-I would replace it. the reason its going down right now is because its in the wrong position from the carwash-these things can be nasty to get off-you can get a tool at the auto parts stores-ie autozone ,advanced auto or pepboys-cheers Denny
Nov 03, 2013 | 2004 Chevrolet Blazer
1046 cub done 120hrs 12mths old replaced all pullies bearing use 5 belts in 12mths belts keep comeing off is this a problem with this modle 2009
hi,
on some cubs there are two holes for the spring loaded pulley adjustment arm. take the deck back off and look at the spring loaded pulley arm mechanism, if theres two holes , take the bolt out that holds the adjustment arm down and move it to the other hole. theres two holes for the spring too, try the other hole, make sure your spring isnt upside down. putting the spring back on is difficult. connect it to the front first then come around the back with a spare piece of rope, put it on the spring and pull on the rope to get the spring back on the mower deck. use eye protection and be careful.
jm
Apr 23, 2011 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
