Question about Canon PIXMA MP210 Photo All-In-One Printer
Can anyone tell me how to fill the brother lc1000 black ink cartridge..thanking u i advance
You do not want to get into that.....by a small laser printer for B&W printing (recommend HP).....less than $100 these days.....25-30 times the yield per cartridge vs. your inkjet!....inkjets are BRUTAL
Posted on Mar 13, 2009
Wont print in black
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Brother DCP-110C All-In-One InkJet Printer
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Ink
better use this generic ink carts, which work pretty much better than the original ones :o
http://www.tianma.net.cn/
http://stores.ebay.de/stonewaregmbh
(LC1000 is identical to LC51)
There is much trouble by refilling original carts, because of the ink which might clog the ph.
Anyway if you keen on inky-fingers, malfunction ph and maybe bad printing results:
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(use google translation german)
Apr 30, 2008 | Brother DCP 130C All-In-One InkJet Printer
Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Refill ink Cartridge
see link:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Doku
(the lc1000 is the same as the lc51)
Refill a max of 12ml for Y/C/M and 20ml for bk.
BTW
brother has changed the inside of the carts. So plz check carefully the pics if your cart looks the same. If it looks different you should drill the hole near the upper valve (the one with the white plastic)!
Nov 20, 2007 | Brother Black Inkjet Cartridge for LC31BK...
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
55 people viewed this question
old marine
old marine
