Question about RCA HD50LPW175 50" HDTV
Bad buzzing sound coming from under the lamp
I hope that someone can shed some light on this this problem. There is a buzzing noise coming from a fan I believe under the lamp in the back of the TV. I checked for any dust in that but it seems clear. I am not sure if this is a common problem and if I can replace the fan or whatever the item is myself or not. Thanks for any info you can give.
  • Gloria Vernon Aug 04, 2007
    Note this noise is not the common noise you hear with this model. The noise is getting progressively louder too.
  • firebyrd Nov 28, 2007
    This is definitely not a bulb issue. It is either the fan going bad or most likely the color wheel bearings going bad. Im having the same problem. Those are the only 2 moving parts in the TV.
    Problem Solver:
  • 5 Answers
Not sure if you found an answer, but your bulb is going bad. Hope you've got it changed out by now...
Posted on Sep 12, 2007
My WD-52525 started a rubbing noise coming from the back area. I figure it's the light engine. Color was off and it won't restart, has a lamp light now. Lamp is 4 months old. Sound like light engine?
This sounds like your color wheel. this will affect the colors on your screen. Do check your lamp though, at 4 months you still should have a good lamp. Unless you have a bad ballast affecting the lamp as well. If you hear a rapid clicking or an electrical buzzing type noise. "ballast"
Apr 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Infocus LP280 Shuts down
the lamp's quality is not good ,the lamp is too hot to work,
We Offer all the Original projector Lamps (bulb).Good quality good price.
Jerry Zhong (China)
Skype: hw998.com
E-mail: hw998.com@126.com
Aug 27, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Sharp projector(xr-10x) lamp wont come on. lamp only 600hrs old. second lamp to have stopped around this stage. could their be any other issue. when lamp did come on projector made a buzzing noise which i...
that noise could be the color wheel. it sound like a fan. but it could be a fan and if fan does not work properly , the lamp would not stay cool.
Maybe you should have a service center look at . before you get another lamp.
thanks doctor video
Jun 07, 2008 | Sharp Televison & Video
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
SAMSUNG DLP BUZZ ONLY WHENBULB IS ON
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
RCA HD50LPW175 50" HDTV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
