My Samsung WD-J1255c simply won't turn on. I have checked the power point and it is fine
SOURCE: Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Posted on Nov 26, 2010
FitzOriginal
  • 842 Answers
SOURCE: WD-J1255C SAMSUNG washing machine is
Best guess is a blocked filter. If the filter blocks, the machine won't drain and if it isn't drained, then the spin cycle won't kick in.
I'm not familiar with your machine, but chances are that there is a filter door at the bottom of the machine at the front that should be opened, the filter removed and cleaned.
I'm presuming that your machine is half full of water at the moment, so in order to remove the filter and clean it at this stage, you would do well to unplug the machine from the mains and then tip it backwards 45 degrees so that the water doesn't escape when you remove the filter! Best thing is to tip it back onto a chai if you are doing this alone, so the chair can take the weight while you undo the filter.
Now.... IF you are unlucly and have no filter in the front then go take a look underneath while it is tipped back. There will be a rubber hose that leads down to a debris trap, then on to the pump. You will need to unclip the spring clamp that holds this in place in order to get access to the debris inside. PROBLEM here: you are unlikely to do this without getting very wet!
I would suggest in this case, repeatedly putting the machine onto spin cycles, it will attempt to drain the water and slowly, bit by bit it will get the water out. Once it has drained (after attempting to put it through a dozen spin cycles probably) you should then be able to access the filter/debris without getting too wet!
If you do have a filter that is accessible through the small front door I described, I would suggest that you make it a monthly task to remove and clean it at the end of a wash cycle to avoid this issue in the future.
Posted on Feb 28, 2011
philwalker78
  • 608 Answers
SOURCE: Rider loses power after mowing for 30 - 45
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Posted on Jun 01, 2011
canwoodjc
  • 3301 Answers
SOURCE: washer / dryer model wd-j1255c
FE in a washer usually pertains to a overfilling usually due to a water valve issue, That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Posted on Jul 18, 2011
gopakumarg43
  • 74383 Answers
SOURCE: mitsubishi wd-52725 wont turn on. no lights,
Hello
The power regulator board of your Mitsubishi TV is faulty. There are two reasons for this fault. The fist one is with its internal protection fuse, and the second one is with component failure to the power supply board. To retify this fault, for both, you must ahve its service manual to follow. User manual provides details about how to use it; where as service manual will have all the details, circuit boards, schematic diagrams, porcieedings to take out and repair the boards, components and it values etc; I can't send the service manual to you by this window. If you want to do this work by yourself, you must have it with you, while I advice you to proceed the work. To get it, you must have to buy one amoung my service published in FixYa website, or go to Google and typw my nickname "gopakumarg43" in its search box. Click on the link "gopakumarg43 - FixYa". You can access my services there. Fixya has placed me on Google, from where you can get straight to me, by mail assistance. I can't touch you by mail, as it is against our Primium Expert's rules and regulations.
The power supply of your TV should be checked. If you have knoledge in electronics and have a concept of soldering, get me by Fixya. OK.
Posted on Nov 05, 2011
My LGL55C powers up and goes to the b lue screen n won't boot up or do anything won't turn off .
Dear Chris,
Seems like a bad RAM. Simply change your RAM and then give your laptop a go and it shall be all fine and smooth sailing on wards. You can test it by simply borrowing a RAM from your friend for a while. But do make sure that RAMS are of same type.
Oct 30, 2012 | Computers & Internet
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
My samsung TL220 i dropped it won't power on or anything
Things to check first for a camera that won't turn on (no power, no lights, no noise, nothing) are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
But if there is some electrical activity, then you're more likely experiencing a lens error. In that case, see this article.
and this video:
Nov 21, 2011 | Samsung DualView TL220 Digital Camera
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
Washer / dryer model wd-j1255c stops on spin and displays F E
Jul 18, 2011 | Samsung Washing Machines
TV will not power on. We have had not problems to this point, it just won't turn on by either converter or using the tv's power button
Please let me know if the unit is totally dead set without the led light at the front panel at all.
Jdvillanueva
Jun 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
