I cant get the Adobe Acrobat Pro 7.0 PDF Printer to work. It comes up with an warning 20225 code; setup was unable to create a new item.
  • 54 Answers
I got 2 possible solutions:
Solution 1: Use a supported installation.
-- If you install Acrobat (Professional or Standard) on a 64-bit operating system, you may see this error. Install Acrobat on a 32-bit operating system.
-- If you install Acrobat to a shared network disk instead of a local hard disk, the Adobe PDF printer is not installed. Install Acrobat on a local hard disk.
-- If you install Acrobat to a directory with a path that contains extended ASCII or double-byte characters, English installations will display the error message. Install to a path that does not contain extended ASCII or double-byte characters.
Solution 2: Ensure that the Print Spooler process is running and set to Automatic, and then repair Acrobat.
1. Select Start > Settings > Control Panel.
2. Double-click Administrative Tools and then double-click Services.
3. Locate the service Print Spooler.
4. If the Startup Type is not Automatic, set it to Automatic:
a. Right-click the Print Spooler.
b. Choose Properties.
c. Choose the General tab.
d. Choose Automatic in the Startup Type menu.
e. Click OK.
5. If the Print Spooler service is not running, then start it.
a. Right-click the Print Spooler line.
b. Select Start from the menu.
6. Start Acrobat, and choose Help > Detect And Repair.
God Luck!!!!
Posted on Mar 12, 2009
I have installed Adobe Acrobat 7 on my laptop that runs on Win 7 platform. However, the installation of Acrobat flashed a warning message that Adobe Acrobat 7 was unable to create a new item: Adobe PDF...
Good Afternoon -
Direct from Adobe, they state that versions 9 and above are compatible with Windows 7, and any versions 8 or prior are not supported and updates to make compatible will not be released. There are two solutions, one that may work and one that will definitely work. The first is to try to install the program under Windows XP compatibilty, natively on Windows 7. To do this, find the executable for installation, right click and select properties. On the comptability tab, click the check box that says: Run this program in compatibility mode for: and select Windows XP (Service Pack #) from the drop down, and proceed to install, running the installer as Administrator. The other guaranteed way is if you have Windows 7 , any version other than starter, you can enable Windows XP Mode which creates a virtual PC of XP on your machine and integrates the program references into Windows 7. Details on this can be found:
Please feel free to contact me with any questions.
Apr 09, 2011 | Adobe Acrobat 7.0 for PC
I have Adobe Acrobat 7.0 Professional, I can not create a PDF from a program file. I keep getting this message: C:/Program Files/Adobe/Acrobat 7.0/Distillr/AcroTray.exe Windows can not access the...
It depends what program made the file. Let's say you made a file in Microsoft Word. You should be able to go to file:print, then when the printer comes up, select PDF instead of the printer. I know this bypasses your Adobe, but it is a way to make a PDF. But, it sounds like the path to your Adobe program might not be right. On your start menu, right click on Adobe and select "Open file location". This should take you to the Adobe exe file that starts your program. If not, you need to find your Adobe folder, and make a new shortcut to Adobe by dragging (right click and hold) to your desktop.
Nov 04, 2017 | Adobe Acrobat 7.0 Professional
I installed adobe 6 professional a few days ago on win 7 computer. but the printer drivers were not installed. i am not able to create pdf documents. also, when i try to download any pdf file from a web...
I am not 100% certain but I am not sure you can use that old a Adobe version with Win 7. The current Adobe Pro for creating .pdf files is now version 9 for Win 7. That may be part of your problem. Consult the Adobe website and see if that older version will even run in Win 7
Dec 04, 2010 | Adobe Acrobat 6.0 Professional for PC
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
Jan 15, 2009 | Adobe Acrobat 6.0 Professional for PC
Unable to create pfd with word 2007 document
That is normal, Word 2007 cannot create PDF documents, it can only save files on PDF but, being PDF non his own format, it will lose document format, and may not display pdf.
To create PDF you need the full version (not the free acrobat reader) of adobe acrobat, or a different adobe software (eg illustrator) that manages PDF.
Adobe Acrobat - How To Create Accessible Adobe® PDF Files Booklet
How to Create PDF Files
Jan 03, 2009 | Microsoft Office Professional 2007 Full...
Adobe Acrobat Pro/Adobe Illustrator
Mare sure your page setup in acrobat matches the page setup in illustrator.
Mar 21, 2008 | Adobe Illustrator
Office 2007 professional and Adobe 8 Professional problem
Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Pdf file
a pdf file is a adobe acrobat reader file. Usually manuals are in pdf file on the cd-rom. you can download adobe acrobat reader from
Dec 07, 2007 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
