Need instructions for proline universal remote to work on my sony rear projection kp-44dx2
Please help me program a proline remote to sony rear projection tv kp-44dx2
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Check this site too.
http://electrohelponline.blogspot.com/
Posted on Apr 23, 2013
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: Sony Kp-fw46m31
count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
Posted on Apr 06, 2008
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
my tv has the same problem but it blinks five time with no picture but good sound
Posted on Aug 01, 2008
ladywinn
  • 5138 Answers
SOURCE: sony kp-51ws520 what bulb does it take
Tube numbers on tubes.Red Green Blue?
Posted on Dec 25, 2008
SOURCE: Sony KP-53HS10 TV Infrared remote sensor problem
Hey, I called the local Sony Authorized dealer/repair. He said the little microprocessor inside the sensor goes bezark once in awhile......soo.......unplug the TV from the wall when you go to bed and then plug it back in the next morning. It worked for me. The little gizmo resets itself.
Posted on Mar 05, 2009
Sony kp-61xbr200 pip wont turn off
The sets made by Sony require the original working remote for this--several different remotes were used--A universal may call up the PIP but not be able to turn it off.
If you have the original remote use the swap or position buttons to see if they function at all--what remote are you using?
Jun 02, 2012 | Sony Convergence Repair Kit For...
I have a 2002 sony 52" rear projection screen and the remote broke. I tried a couple of universal remotes but they dont work. Is there a remote that is compatable with it or do i need to purchase a new...
Try website 1-800-Remotes Factory original.Buy an exact remote.Best,because codes,sometimes codes in the manual wouldn't work u find that out.Must keep the dam manual safe all the times,like battery dead,or run low.Must re enter the dam codes again.
Apr 12, 2010 | Sony KP-51WS500 51" Rear Projection...
We have a Sony KP-53S25 the Universal Remote Changed it to aux
Hello, I'm looking for a supplier of power sony kp
KP-53S25 if they can get or ayudareme a solution I propose.
Freddy Perez
freddybbg@yahoo.es
Feb 07, 2010 | Sony KP-53S25 53" Rear Projection...
Need the code for the remote for a sony kp-51ws510
You need a Sony original remote--even a Sony universal will not access the menu.
With the Sony remote (Almost any Sony projection remote will work) you can adjust in the customer mode or enter the TECH menu for fine adjustment all over the screen.
If you get one and do not know how to enter the TECH menu--let me know and I will tell you how to do it and adjust there.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a universal remote and need the code for a Sony Videoscope XBR projection tv
I don't know if all codes are the same. Comcast Cable gave me a list of codes for their universal remote for their motorola cable boxes. For Sony tvs it says either 0000 or 0111. I still use all 7 of my remotes. Universals are basically only good for power and volume. I need the other remotes handy to enjoy the other functions of my system! Anyway, hope this works 4-u and that you get better use out of it than me.
Sep 01, 2009 | Sony KP-51HW40 51" Rear Projection...
Can not get ride of the green "VIDEO" OR "LD" SYMBOL ON SCREEN
Solution was, I had to buy a universal remote control that had a button that read "display", The Radio Shack store was the only store I found that remote, it was only $9.95. I programed the remote to the TV code..easy and pressed display button...and the problem was solved.
I Thank everyone for viewing my problem..it was a local TV repair store in my area over the phone told me the solution,,Thanks again.
Jan 17, 2009 | Sony KP-43HT20 43" Rear Projection...
How to program RM-Y902
http://www.manualshark.org/manualshark/files/4/pdf_9380.pdf
ok i was looking over your manual for your specific tv it doesnt show that you can program this particular remote for the product listed
my suggestion is go out and by the fancy universal remote since you have the better quality tv universal remotes have a better way of programing everything together
hope this helped
Mar 24, 2008 | Sony KP-53HS30 53" Rear Projection...
Remote
Make sure that the sony remote is working and the universal remote is programmed correctly by using them on another Sony television. You can try a set at a store that sells TV's. If the remotes are working, then the number one suspect is the Remote Receiving Unit (RRU) inside the set. The microprocessor does cause this problem, but, it is rare. Hope this helps.
May 12, 2007 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
