Question about Samsung PCN5425R 54" Rear Projection Television
Triple Vision Overnight the projection television is out of focus weavy fuchia pick and green lines starting at the very top of the screen. Please help.
  • 398 Answers
One of your convergence output IC's has stopped working and needs to be replaced. This is a very common problem in projection TV's. The IC should be replaced and the convergence circuits realigned by someone with experience in repairing projection TV's.
Posted on Aug 05, 2007
I HAVE DOBBLE AND TRIPLE VISION HOW DO I FIX IT
This is caused by a blown fuse on the convergence circuit. There will be missing menu items in the service menu as well when this fuse is blown. You must replace the small block type fuse and then enter service menu and converge the television back to normal. This requires removal of the main board, unsoldering the component and replacement, and then alignment.
Apr 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have triple vision going plus it has started to
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I get a split up of red and green in a wave at top of screen
The convergence ICs and resistors are the most likely things to cause that. You can get the convergence repair kit for the DP14G hitachi( 53UXX10B) at the following link which contains the parts and instructions.
http://www.tvrepairkits.net/
Jul 11, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
My 1080i has a triple picture, can you help?
It definitely can be fixed the IC chips (called STKs) that line up the images from each picture tube are failing.Sometimes a fuse or resistor go out along with the chips. The parts would cost around $100 + whatever labor charge if you hire someone.
Apr 29, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Lamp issues
No its a tube and not a bulb. If thew line is green then theres an issue with the red and blue as the green is stationary on most sets unless thers a green centering ? Its a componet on the convergence board thats bad or going bad but if you replace any components on the board most likly your gonna need to do a convergence alighnment I would let a pro handle this repair unless your an experineced repair tech Good Luck
May 21, 2006 | JVC AV-56WP30 56" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
