Question about Pioneer PDP-4360HD 43 in. Plasma Television
Pioneer PDP-R05G I have a Pioneer PDP-R05G receiver w/ PDP-435PG display it made a loud pop and now the display is black. When I turn the receiver on it it makes a clicking sound and then about 5 seconds later makes another click and the fan stops. The display LED light stays red throughout all of this even when I try using the remote. Any suggestions?
    Top Expert:
  • Pioneer Master
  • 74,383 Answers
A clear symptom of panel failure is described here. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. Replacing panel will cost around 80% of the total cost of a new TV http://electronicshelponline.blogspot.com/
Posted on Apr 23, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
SOURCE: How to play PDP-434PG with PDP-R05G
Are you still struggling with PDP-R05G?
Mine has 'died' with green light flashing 8 times. Would you be interested in selling your receiver? 07-5444-5521
Posted on Feb 06, 2011
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Do I need a digital set top box if I have a pioneer PDP-R05G media reciever
Turn the receiver on and select TV. If you can't tune X.X channels (no decimal), you need the converter.
Apr 02, 2017 | Pioneer Televison & Video
I am looking to buy a Pioneer media receiver model PDP-R05G - can anyone help me? This suits plasma panel PDP-435PG
I am also looking for a PDP R05G receiver.
If you're upgrading your TV to digital, let's know if you'd like to part with the redundant analogue R05G
Ian +61 7 5444-5521
Apr 14, 2010 | Audio Players & Recorders
I do not know how to solve your issue sorry, I need the media centre you have for a PDP435. Would you like to sell the media receiver PDP-05G ?
0212624139
Aug 27, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
I have a Pioneer pdp-433 plasma with a media receiver pdp-ro3e. When switching it on it gave a loud pop and blew up a fuse in the meter cupboard. Now when switching it on it gives green light on receiver...
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Jul 13, 2009 | Pioneer PureVision PDP-4330HD 43 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PDP-4360HD 43 in. Plasma Television Logo
262 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
