Question about Sony KP-51WS500 51" Rear Projection Television
Colours are seperated
The colours on my TV are seperated so it looks like it's supposed to be showing a 3D movie, but I tried using 3D glasses and that doesn't help either.
I believe it's called a convergence problem?
How might I fix this myself? I know how to solder.
  • cook2039 Mar 23, 2009
    i have a sony kp51ws500 rear projection tv all the color are seporated
    Scholar:
  • 41 Answers
There is a good chance the IC's that control the convergence are blown. I will do the best I can to describe them since I don't quite remember where they are on this set. They are a pair of identical chips which I believe are on the main board on this set. They are attached to rather large heat sinks and they have STK-###-### written on them. The # indicating an actual #. For example, STK-192-110. If you decide to change these yourself please keep in mind, TV's produce very high voltage and sometimes can retain it even when the set is unplugged. (anything associated with the thick red wires) Also make sure you use new heat sink grease which you can usually get at the same place you buy the chips. I was able to change mine however I had to remove the chassis. Please keep in mind that this solution is based past encounters with convergence issues and doesn't guarantee this is the same problem. Let me know what you decide, hope this helps.
Posted on Mar 13, 2009
  • 29 Answers
Lol.. it is not i believe most cases ( if ) your tv have had seen repair before ? check the yoke connections on the housing bases most of the times the electrical safty wires melt down from excessive heat causing the yoke to disbalance ( but that also means blurry picture) if no blurriness ? then it may be the STK video chips , in my case i have a sony model and the chips are located in the lower case of the front of the tv face ( right under the front AV or audio casing ) . to replace them you have to open the dual screens ( covering the main speakers ) by unclipping them , then using a philips screw driver #2 unbolt the 4 screws to open the casing and access the verdical front pannel ( the chips are rectangular in shape and aproximately 3 inches long seated also verdicaly peralleling eachother , write their sku or class or model # )they usually called STK chips
Posted on Oct 21, 2012
What makes the picture projection appear in seperated colours ?
Usually it is a convergence chip but that depends on brand and model number---some of the sets do not use them.
Look first in the menu to see if customer adjustment of convergence is there---for example if a RCA 2002-2006 and no convergence adjustment shows it is gone for a reason.
Oct 21, 2012 | Televison & Video
The colours are no longer lining up. On captions you can see the three seperate colours. The auto focus does not fix. How do you enter service mode to adjust grid lines?
U can't do any grid lines adjustments for this problems,the tv problems it is having are known as a convergence pictures problems,it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is dead for the tv to causes all of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost like $300-350 for parts and labors.
Sep 21, 2011 | Toshiba 57H83 TV
When switched on colours fine after short period colours seperate causing a 3d type effect
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 21, 2009 | Samsung HCN4226W 42" Rear Projection...
My RCA 52 inch hdtv 3d of the colours.The three colours are all showing in a streak like a rainbow
U know how to solder?Buy a convergence kit,replaced what in that kit ur tv will be back to normal.Tries these websites for the convergence kit.Tv Repair Worl.com,Tv Repair kit.
Oct 23, 2009 | RCA HD52W59 HDTV Projection Television
Looks like 3D with out the glasses
you need the phillips dptv 305 - dptv345 chassis convergence repair kit which contains both convergence ics and all feed resistors and also free installation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sony KP-51WS500 51" Rear Projection Television Logo
134 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
