Smb 1101 scan error
When i scan documents to computer i got smb 1101 error
  • 214 Answers
SOURCE: can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Posted on Nov 12, 2008
SOURCE: SMB Scanning
I had the same issue and fixed it by adding the group "Everyone" to the shared folder permissions (where I was sending my scans) and assigning the "Everyone" group rights to "change" and "read".
Posted on Jan 20, 2009
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Posted on May 27, 2009
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
  • 11 Answers
SOURCE: I am getting an error message 027-516 server
SMASH IT WITH A HAMMER NOWWWWWWWWWW
Posted on Nov 17, 2009
Document scan to SMB for w8.1 pro for
That model does not support scan to smb
the only scanning it support is
TWAIN (scan-to-Pc and Scan-to-Email only via Software QLINK
Aug 19, 2014 | Kyocera Mita Olivetti D-Copia 163Mf...
Error type connect model 1128
The following is the list of info required to setup smb scanning. The easiest way to enter it, is via the devices webpage. Make sure the folder is fully shared.
"Host Name" = The computers name
"Port Number" = Either 139 for windows XP computers or 445 for windows 7 computer
"Path" = name of folder where the scanned documents are sent/saved.
"Login User Name" = Windows user name
"Login Password" = Windows login Password
Feb 24, 2014 | Kyocera Office Equipment & Supplies
SMB
check if there's an error code in the completed queue.
Also it would be helpful to know what kind of operating system is on your computer since MAC and Windows 8 are not that easy through SMB.
Check if you shared the file on your computer to full acces rights
May 28, 2013 | Konica Minolta Bizhub C454 Color Copier
Error 1101
This scanning problem usually referes to the printer not finding the host pc when try to establish contact before a scan is sent to the pc. Access the device through the browser and check in the profile for that pc in your address book whether the pc name is spelled correctly in the host field at smb scanning. Sometime it will be an option to use the pc ip address instead of the computer name ( provided it is a static ip address. ) this should resolve the problem
Apr 04, 2013 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
1,101 people viewed this question
k24674
jasbo
jasbo
