Kenmore elite 11024962301
Starts running after short time it stops will restart after 20-30 min. on its on?
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
jsrock516
  • 5911 Answers
SOURCE: ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Posted on Jun 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Posted on Jul 25, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite he3 flashing FH
The following link explains the "FH" error:
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: kenmore elite oasis washing machine gives the code F1
the machine needs to be rebooted. Unplug the machine for at least 10 min then plug back in and push pause or stop 2 time.
Posted on Feb 27, 2010
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Kenmore elite microwave 79203 buzzes when off
It sounds like you have a shorted cook relay on your control circuit board.
That can usually be repaired more economically than replacing the circuit board.
Jan 09, 2013 | Kenmore 79203 Elite Stainless Steel 2.0...
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Stops after 20-30 seconds but only when using heat. Can immediately restart.
rbf, in looking Im not finding a 649732, but I do find a 649723. This dryer has a even heat board but also a thermistor. If you had to hold the start button for it to run, I would suspect the even heat board. That's not the case so Im suspecting a open or shorted thermistor. If you remove the lower panel it sits right behind the blower housing next to the thermal fuse. Should be black in color. Part number 3976615. The thermistor should ohm out at about 10k ohms plus or minus 3. When one of these thermistors fails usually you get the symtom your describing. Catriver.
Jun 23, 2007 | Kenmore 64952 Electric Dryer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
