This solution will work provided your Administrator login has no password, by default computers will not have a password on the administrator account and typical setup will have you using a seperate login.
when booting up your comptuer after post (the beep) press the F8 key. you should get a display that says Safe mode boot normally ...
Select safe mode. when booted either Type in "Administrator" or select the Administrator login if you get the welcome screen.
from there goto your control panel and select user accounts.
from here you can remove the password for your typical login
