Question about Timex 27191 Wristwatch
FMDWS041 Taking out links to band
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 | Watches
Need to shorten metal watch band
here is a solution..
Each removable link on the watch bracelet has an arrow that indicates the direction of the pin to be pushed out .first decide how many will go out than find a tiny nail to be used as " pin pusher"
Simply align the pin that connects the links with the pin on the wood table and with a small hammer/plier hit it to push the pin out...there it comes..and after taking out linls ,connect the remaining link parts together and put the pin back into....
Some people prefers to use a pro type pin remover..it is a cheap tool..just in case pls visit the URL below..on this link there is an article as Watch Band Adjustment Tool Link Pin Remover too..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://reviewsalert.com/watch-repair-kit-16-pc-deluxe-tool-kit-repair-pin-remover/
Sep 11, 2011 | Watches
Taking off a link from a citizen eco drive watch band
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, You"d need a tool to remove that link, by the time you get the tool, the time to remove the link, is about the same cost of haveing a shop do the job.
Jul 04, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 | Watches
Taking links out
push the pins out in the direction of the arrows on the underside of the band.
Jan 01, 2010 | Timex Sports Ironman Triathlon 100-Lap...
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
I can not get the watch band to fit my wrist. How do i shorten the band
If it is a metal band there are links in the side of teh band that you can remove. If all teh removable links are gone you may need to change the band into a smaller one. And there are little pins by the watch you can do that as well. I recommend taking to a jewelry repair shop. Some jewelry store do repairs as well, and may have parts you need for this as well as the tools.
Dec 12, 2008 | Watches
How to remove link from band
The segments of your bracelet are held together with friction pins which have to be removed first in order to adjust it. This is a relatively complicated task requiring experience and a special tool to remove and return the pins and bushings back correctly without compromising the bracelet strength.
I recommend taking your watch to an Omega authorised dealer for adjustment while you wait.
Nov 09, 2008 | Omega Seamaster 2541.80 Wrist Watch
I bought 2 Fossil watches today and need to shorten the wrist band by a link. Both watches have indicators which link can be taken out, yet the arrows show inwards.....
The pins on these watches can be taken out either way, you don't have to worry about if your taking or putting the pins in the wrong way. If you have anymore problems PLEASE let me know. Good Luck!!
Aug 09, 2008 | Fossil Watches
Timex 27191 Wristwatch Logo
71 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
