Question about Maytag MFF2557HES Stainless Steel French Door Refrigerator
How to examine MFF2557HES evap fan?
My fridge stopped cooling a week ago but freezer works fine. I threw my food out, unplugged the thing and left doors open, for 2 day... maybe something to do with frost. But no, I plugged back in and still same problem. I called a service shop and they said most likely the evaporative fan that blows the cold air from freezer up to the fridge part is stopped or dead. Does that sound probable? It this evap fan something that I can examine and replace myself? I'm not afraid of taking things apart as I'm a computer techie myself. Do I need a hammer?
  • Anonymous Nov 20, 2008
    ours just had the same problem and died
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Yes, if you're not afraid of removing service panels and replacing parts, then this is something that you can probably replace without too much trouble. Very straightforward, just remove the fan motor assembly & screw a new back into it's place. And yes, that sounds very probable if you've already tried defrosting the machine first.
Posted on Aug 04, 2007
SOURCE:
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
Refrigerator stopped cooling but the freezer still works fine
you should have sent the model number so i could look up your machine,open the freezer door,do you hear the fan blowing in the freezer?if not you have a bad evap fan motor,if the fan is good you could have a bad damper located in the fridge section,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air over into the fridge section,it could just go through an air duct or through a damper,if there is a damper most likely this is your problem or check the back inside wall of the freezer and see if there's any frost on it,you could have a defrost problem or the door could have been left open and the air ducts frose up,also if the freezer is on top you could have a blocked drain in the freezer and the air ducts are iced up,look under the crisper draws to see if any water is under them if so the drain is blocked.these are the things to check,if you send the model number and a little more info i can help you out better
Sep 04, 2012 | Amana Refrigerators
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Hi, I have a kenmore coldspot 106.56152500 and the fridge has stopped working. I can hear it running but it is not cooling at all. The freezer is still working, however, not as cold as it should be. I...
Yes the most likely reason for not defrosting is your=> W10135901 Defrost Control Board
The defrost control board can be found inside the fresh food compartment behind the control panel where you adjust temperatures for the refrigerator and freezer. To gt to the control board you need to unplug the refrigerator and disassemble the control panel. Look over the control board sometimes you may see signs of heat damage but not always. If you have questions I will be here so please ask, Thanks Sea Breeze
106.56152500 Parts
Jul 03, 2012 | Refrigerators
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
Actually a side by side freezer's way cold but fridge won't cool.....started it 3 hours ago empty
ck the dampner control as it controls the air flow to the fresh food side. also see if the evap fan is working .. inside the freezer side . this blows the cold air to the fresh food side. mm
Aug 10, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Maytag MFF2557HES Stainless Steel French Door Refrigerator Logo
233 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
