A635 speaker logitech
Possible cord broken need a non moulded plug ? to shorten cord at damaged area
2 Suggested Answers
SOURCE: polarity of compaq computer speakers
why can't you chek with google web search
Posted on Apr 07, 2009
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
How to open/repair Logitech S100 speakers for the power cord replacement?
first open the net over the speaker...top bottom corner there is a hole then in this hole put a strength stick pressure heavy by side..then it will show u crack by this crack u have to open it!!remind there is no screw in s-100 logitech speaker!!Thanx!
Feb 07, 2013 | Logitech S100 Computer Speakers
My logitech z130 speakers suddenly stopped working. I use them frequently with my laptop. they worked perfectly, but 10 min. later i tried to use them and the green light would not come on. i wiggled the...
sounds like the inner cable is broken,either at the speaker end or the jack plug. but if there new take them back to the shop they should be under guarentee
Sep 16, 2011 | Logitech Z130
Power intermittent when lead moved near entry point
sounds like you have a broken wire in the cord in the strain relief area. what you can do is unplug and make a wiring diagram and then remove the cord and GENTLY pull the wires one at a time to check and if broken you can shorten the cord that length and continue using tool.
Apr 18, 2011 | Hilti Drills
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Need to replace the 9 pin male plug that goes into the woofer box,so need pinout diagram
All I wanted was a pinout diagram for the male plug so that I could wire up a new plug. Did not want to have to re-mortgage the house to get that. Thought such info would be free.
Anyway have stripped away all the plastic moulding to reveal the connections so am OK now Thanks
Jim Goldsmith
Jan 18, 2010 | Logitech X-530 Computer Speakers
Here's my problem: I have 5.1 logitech speakers. The plug where the yellow jack goes into the subwoofer seems to be broken. No sound coming from this speaker (rear left). The problem isn't in the cable...
2 possibilities, either the connection coming out of the sub has gotten disconnected on the inside of sub or that channel is bad on your amplifier in the sub. The only way to know for sure is to open the sub up and ck.
Aug 02, 2009 | Logitech X-530 Computer Speakers
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
SoundSticks HUMMING/BUZZZZZING
the cable is broken, you have to replace it or find out where it's broken and shorten it
Dec 05, 2007 | Harman Kardon SoundSticks Computer...
52 people viewed this question
 Grubhead
Grubhead
