Question about Music
PICK-4100 49 keys multifunctional electronic keyboard
Bought second hand, no manual
Casio keyboard CTK-519 manual
http://support.casio.com/manuallist.php?rgn=1&cid=008
The link i have attached is a direct to Casio's website and their user manuals. i dont think the one your looking for is on the however, you might find a model very similar to yours to use as a reference.
is there a problem your having with the keyboard?
Oct 23, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Manual Casio CTK-650
Hi! When I turn on my keyboard it shows "03.2" on the multifunction display and the lights of "Split", "Digital effect" and "Touch response" remain "ON" and in someway it get blocked for the most of the functions. I cannot turn off that lights. Please, help me!!! You can answer me to dramosm@hotmail.com Thank you very much
Sep 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
We hava a Casio CTK-601 Synthesizer Keyboard. It was accidently left plugged in with a 12 volt adaptor. It uses a 9 volt adaptor. We do not know if it was having the following problem before or after...
That is a good detailed description. The factory reset is a good idea.
It sounds like a corrupted firmware. 12 volt instead of 9 volt is not a big overload, depending on the design. The fact that the adapter was very hot points to a serious electronic fault perhaps occuring. If the amp rating of the 12 volt one is adequate, this is probably the case. The 12 volt adapter could also get very hot if it is under rated for the job, which gives no real information about the fault.
It is possible that the electrolytic capacitors in the power supply could have been stressed and the power supply is now inadequate. The service manual would be handy in this scenario. If the digital electronics is corrupt or damaged, the chance of an economic fix is much less.
Feb 27, 2011 | Casio Music
I have a CTK-496. I bought the usb to connect from the keyboard to the computer. When I have it activated on Fl Studio, but I press the keys, nothing plays but the regular keyboard. Its like the keyboard...
You have to install the MIDI type software in the PC to trigger the sound card's voices. You may also need a driver for the keyboard. Search the Casio site for downloads pertaining to your keyboard.
Dec 27, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
How to remove keys for complete cleaning
I've worked on a lot of keyboards and they're all different.
Unless you have the service manual, a good set of electronic tools and have the time, don't attempt it, take it to a keyboard services specialist. If they know what they're doing, you'll get you keyboard back in good working condition.
Apr 30, 2009 | Music
Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Dec 30, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
From left hand side 10 keys not working
You might check settings first. The keyboard might be set to a mode where those keys have some function besides notes. Try a master reset and see if hings start working.
If it was working and now those keys don't, a fault has probably developed. There may be problems with connections to the keyboard, or there's been a component failure.
Sometimes getting into these things and accessing the keyboard is a challenge, and it's possible to do more harm than good. If it needs repair, you're probably better off taking the keyboard to a musician's store in your area and asking them to give you an estimate for the work (or to recommend a servicer if they don't do the work themselves).
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
48 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
