Question about Tomtom ONE GPS Receiver
HOW CAN I KEEP MY TOMTOM FROM TURNING OFF EVERY FEW MINUTES? I CAN TAP IT AND IT WILL COME BACK ON AND GO OFF AGAIN.
  • 515 Answers
There might be a function that saves power between route instructions, try to turn this off...
Posted on Apr 13, 2009
What i need to do to fix my tomtom?
26
Preferences
Use night colours / Use day colours
Show POI on map
Use Night
colours
Tap this button to reduce the brightness of the screen and show darker
colours on the map.
When should I use this?
When it's dark, it is easier to see the screen if the display on your ONE is not
brightly lit.
Use day
colours
To change back to a brighter screen showing brighter colours on the map,
tap Use day colours.
Show POI on
map
Tap this button to set which categories for the Points of Interest (POIs)
should be shown on the map:
1. Tap Show POIs on map in the Preferences menu.
2. Select the POI categories to display on the map.
Tap Find to search for a POI category.
3. Tap Done.
The POIs you have selected are shown as symbols on the map.
May 27, 2014 | Tomtom One GPS
How to change language from Spanish back to English?
When you first switch on your device, you have to answer a few questions to set up the device. When these questions appear in the wrong language, it's best to soft-reset your device.
Devices which are reset by holding the On/Off button:
Press the On/Off button and keep holding it until you hear the TomTom start sound. This takes at least 15 seconds. Also keep holding down the On/Off button if your device switches off or shows the start-up screen.
Devices which are reset using a paper clip or pen:
Press the reset button using a paper clip or something similar for 15 seconds. Then press the On/Off button for at least 5 seconds.
To change the language on your navigation device, do the following:
  1. Tap the screen to bring up the Main menu.
  2. Tap Change preferences.
  3. Tap the arrow in the bottom right corner until you see the Change language button. Tap Change language.
    Follow the instructions on the screen to confirm your language selection and choose a voice.
May 24, 2011 | Tomtom XL 340 43Inch Portable GPS...
My TomTom Go 910 will sometimes not turn on, sometimes hangs on the black TomTom screen and will not turn off, a hard reset will get it going again. It also keeps turning itself on when I'm driving. I...
I think it is the same dock contact problem.
the battery won't charge and can't supply enough
power for harddrive to rotate and it shutdown by itself.
Feb 02, 2010 | Tomtom GO 910
We want to reset the clock from am to pm or start beginning questions all over again.
1. Turn on the TomTom unit. 2. Tap the screen to bring up the menu. 3. Tap the "Change Preferences" icon 4. Keep hitting the arrow to go to the next page. Clock setting is on page 6 of the preferences dialog. 5. If the Set Clock option is greyed out, you will need to perform a system reset and then perform these steps over again.
To reset the system, start with the power off. Then, hold down the power button for about 15 seconds, until you see the TomTom logo appear on the display. When the logo appears, release the power button. After this reset, you should be able to turn the unit back on and proceed with your setup from scratch.
Nov 27, 2009 | Tomtom XL 340S Car GPS Receiver
All I have is a flashing signal that says waitig for valid GPS signal
Another thing to try:
Tap the satellite bars in the lower right corner. This will bring you to a screen called "Status summary." You'll see satellite bars on the right-hand side of the screen. Tap them.
This will bring you to GPS Status. Tap "Configure" in the lower left corner. Change the coordinate display to D.D (or if it's on D.D right now, change it to DM.M). Tap "Done" then "Done" again.
Has that fixed the problem?
Nov 24, 2009 | Tomtom One XL GPS Receiver
My tomtom will not swicth on (fully charged)
Try holding power button for 10-30 seconds. If that doesn't work, pull that battery out for a few minutes, put back in and give it a try again.
Oct 08, 2009 | Tomtom ONE GPS Receiver
Last week I updated my TomTom One with the latest maps, etc. Since then whenever I use my TomTom it keeps displaying a "Shutting down in 10 seconds" screen, with follow up screens, and then it shuts down....
Make sure you have "never turn off screen" checked, To do this tap "change prferences" tap the forward arrow until you see "battery saving preferences". Tap "battery saving preferences" then tap "never turn screen off". Tap "done" and make sure that "switch off when external power is lost" is not checked. Tap "done". If you do not see this option go back into "change preferences" tap the forward arrow until you see "show menu options" it should read "show fewer munu options"
Sep 26, 2009 | Tomtom One XL GPS Receiver
My Tom Tom One takes a long time to pick up a GPS signal (30 to 45 minutes)
You might want to try updating your TomTom through TomTom Home. It loads something called "QuickFix" onto the TomTom, which I guess tells the TomTom where GPS satellites are going to be. I get a fix in about 5-15 seconds if I keep this updated, otherwise it takes a few minutes.
Aug 01, 2009 | Tomtom One XL GPS Receiver
My tomtom 530 is on finish how do i put it on english
Turn on your TomTom and on the map screen tap anywhere, next tap the wrench at the bottom next to the forward arrow, tap the forward arrow until you see a icon of flags, tap the flag icon and set your language
Jul 07, 2009 | Tomtom GO 720 GPS Receiver
MY TOMTOM ONE IS WAITING FOR A VALID GPS SIGNAL I HAVE ALREDY STARTED TWICES
Turn on your tt and let it bootup. After it has booted up go to the map screen. On the bottom right where the bars are for satellite reception. Tap the bars this will take you to the screen telling you the device code etc. On the upper far right where the battery icon is tap the screen again. This will take you to a screen showing the satellites. If you see grey bars on the graph just wait awhile. Sometimes when your tt has not been turned on for awhile or you have turned it on after traveling a few miles it may take up to 30 minutes to get a lock.
Hope this helps
May 06, 2009 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
