Question about Lexmark P4350 All-In-One InkJet Printer
Photo mode problem
Hi there , Whenever i turn on my printer it comes up with " The memory card formatting is not supported. Format the card in your digital camera." even when there is no card inserted in the printer, I also cannot change the mode from photo to print, scan or anything. HELP!!!!! Thanx
  • Dave Cooper Aug 12, 2007
    Hi KOakaKO
    tried doing all of that but to na avail, as soon as the printer is turned on that message comes up, thanks for the help
    Novelist:
  • 135 Answers
Usually if you completely uninstall the drivers and software that came with the printer, then reboot your computer and reinstall the drivers and software - it will make a problem such as you describe go away completely. If it doesn't, then a technician will need to physically inspect your machine for problems. You also want to be sure that you have the most current version of the drivers and/or software for your machine. The Lexmark Driver download page for your model is here: --> http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0 Hope that helps. ;)
Posted on Aug 04, 2007
SOURCE:
My memory card says you need to format before use it, but I dont want to do so because there are alot of photos are saved in
Transfer the photos to a computer and then format the card. Use a card reader if necessary.
The problem occurred precisely because you haven't regularly formatted the card.
Jan 23, 2012 | Cameras
Hi how do i formatt my camera card
From page 63 in the manual.
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
Jul 05, 2011 | Samsung Digimax 201 Digital Camera
Canon selphy cp780 when i insert memory card a question mark comes onto screen and doesnt recognise any photos the photos are in jpeg i am using a compatible memory card
Are you able to upload the photos to your PC?
If so, transfer them to your PC then format the memory card using your camera or PC, then download the photos back to the memory stick & insert once more into your printer.
Let me know if this procedure resolves the issue.
Best wishes,
Graeme.
Mar 12, 2011 | Canon Office Equipment & Supplies
Whenever I try to view newly taken photos, it loads for a really long time and the light flashes oranges and reds. So I turn it off and then can't turn it back on until I have opened the bit where the...
Hi!
Posible solutions:
1. Try to format the memory in the Camera and try if it works ok.
2. If you have problems formatting with your camera download the "HP USB Disk Storage Format Tool" that will repartition and format your memory card.
3. If none of these steps work for you maybe your memory card is broken. Try Another one on the camera.
Hope this helps!
Mar 05, 2011 | FUJIFILM FinePix S1600 Digital Camera
In photo mode the camera viewfinder go's off but the lense does not retract, in viewing photoes mode it works perfectly
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 18, 2011 | Fuji FinePix 2800 Zoom Digital Camera
Can't Transfer Photos From SD Card To Computer
were pic on camera before you started;if so it should work'
May 01, 2010 | SanDisk 2GB microSD Memory Card
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Wrong SD cards????
Your printer may have issues reading SDHC memory cards. The Secure Digital 2.0 standard (SDHC) is not backwards compatible and requires SDHC compatible devices in order to function.
http://www.promaster.com/support/cardreader/sdhc.asp
Jul 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
364 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
