Kenwood ka 880d
Left-Right channel knob has lost contact (on left side). No sound coming through; somtimes intermittent. Can this be fixed?
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
hawkwatcher
  • 67 Answers
SOURCE: left channel not working
Probably Broken solder connections in unit. I have seen these units have many poor broken connections throughout amp espcially around poweramp ic .IC701
I have a service manual if you are interested in it kstahl65@att.net
Posted on Jan 15, 2008
SOURCE: Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Posted on Jan 23, 2008
  • 4234 Answers
SOURCE: Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
Posted on May 08, 2008
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
May 10, 2015 | Kenwood Audio Players & Recorders
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
Kenwood ka 7x
salut a tous quelq'un a un amplificateur kenwood ka x7 je veut connaite les tronsistors qui porte cette amplificateur le mien etait enlevr je connais pas les refferonces je demonde de l'aide et mercie beaucoup a +
Oct 05, 2013 | Televison & Video
KA-994 Model Right speaker channel not working. How do I fix it?
Hello
Check the speaker of the right side first for damage. Connect it to left side and listen whether it works or not. If it works with left side, make sure that the audio output section circuit to the left side inside your amp has damaged and should be replaced. If the speker does not works with connecting it to the right side, make sure that the speaker has damaged. OK.
Dec 23, 2011 | Audio Players & Recorders
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • Oct 19, 2011 | Kenwood Car Audio & Video
    I lost the wiring color codes for my kenwood KDC-MP628 CDReciever
    http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm for the deck
    1) Remove the ashtray and the two outermost screws exposed in the ashtray cavity.
    2) Remove two screws from each side of the dash console.
    3) Remove the climate control knobs.
    4) Unclip the trim bezel and remove.
    5) Remove four screws securing the car stereo to the dash.
    6) Pull car stereo from console releasing antenna and connectors.
    Constant 12V+ Red Switched 12V+ Orange/Yellow Ground Black Illumination Red/Green Dimmer Green/Red Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Orange Left Front (-) Black Right Front (+) Gray Right Front (-) Green Rear Speakers 4" Tail Gate Left Rear (+) White Left Rear (-) Red Right Rear (+) Yellow Right Rear (-) Blue
    Jun 16, 2009 | Kenwood KDC-MP628 CD Player
    Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
    please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
    nuwan.
    Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
    No output from left channel after crackling sound
    Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
    The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
    I'm amateur radio and engineer
    Jul 08, 2007 | Marantz SR-4200 Receiver
     Grubhead
    Grubhead
