Question about Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker
Hamilton Beach Problems
Water remains in the tank where the water is poured even after coffee maker finishes brewing.
    New Friend:
This is my 2nd of these coffeemakers, and our favourite, and it's no longer available in Canada, so we have become experts at it! When that happens (and it's happened more than once) we give it a good cleaning with CLR. If you've really let it gunk up, it might take more than one cleaning to get it draining fully. But we've resurrected this coffeemaker when we thought it was a goner! Give it a try. And - watch the "clean me" indicator in the display, it's there for a reason! If it lights up, run a cleaning cycle with CLR immediately! Good luck!
Posted on Sep 07, 2013
5 Suggested Answers
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
djbash
  • 36 Answers
SOURCE: hamilton beach brew station leaks
chances are, you're filling the machine up with too much water. look at the water resivoir and see if there's a hole somewhere toward the top or a marking indicating the water limit.
-Bam-
Grape Jelly
Posted on May 06, 2011
tcman1169
SOURCE: Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Posted on Dec 26, 2011
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Dec 26, 2011 | Hamilton Beach BrewStation
Hamilton beach brew station leaks water all over when filling the coffee maker - no problem once the coffee is brewed...why is the water leaking???
-Bam-
Grape Jelly
May 06, 2011 | Hamilton Beach BrewStation 47214 Coffee...
How to clean Brew Station
Remove the water filter, if you have one. Pour 2 cups of vinegar into the water reservoir. Turn on, wait 20 seconds, and turn off. Leave for 30 minutes. Then turn on, and turn off when finished. After it has cooled, dispense several cups, then empty and rinse the reservoir. Run two or three more cycles with (clean) water only, allowing to cool between the cycles.
Mar 17, 2011 | Hamilton Beach BrewStation 47214 Coffee...
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
Keeps shutting off after one cups is brewed even if filled for 10 cups
Hi, this is a common problem with Hamilton Beach on several models. There are also a host of other problems with them. There is no fix for these coffee makers. They are "throw aways" have owned them myself in the past and understand your problem. Sorry to sound so negative but Many people are disappointed with Hamilton Beach.
Good Luck.
Aug 17, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker Logo
126 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
