Question about AMD ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce4 SLI X16 ( Sold Out) (ASA8N32) Motherboard
A8n32-sli deluxe was working ok, now doesnt see the sata ports
Rig has worked fine for a year, i paused a game, came back to find blue screen with exceptional error showing. i have 2 opticals on ide2, 160g ide hdd on ide1 but also 2 x 80g sata hdd. Now the comp wont startup because XP is on one of the sata drives and none of the sata drives are being recognised anymore. Swapped sata hdd to spare m/c with their cables etc they are seen fine, Been into BIOS, settings are set to sata enabled ok, Cleared the CMOS and checked settings again, none of the four sata sockets seem to be working. Its been suggested i should flash an updated BIOS, is that a likely solution?
  • pete_sisson Mar 13, 2009
    Tried ram swap/change positions (corsair cmx1024-3500LLPRO X 2) no change. Facts are that any IDE hdd or CD/DVD drives that are connected to IDE1 or 2 are "seen" and work fine, but any SATA HDD plugged into any of my 4 sata sockets are not "seen" at all. Thats my big problem because my OS XP is on my SATA drive so hangs up asking for an HDD with OS on. Tried the SATA drive in a spare comp. and its "seen ok". The computer has been working fine for 18 months and was on when it decieded it couldnt see the SATA sockets anymore.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    pls consider changing RAM and let me know if it helps BIOS is not a solution here and might be risky in some cases it can completely ruin ur motherboard if not loaded properly no use for bios in this case
    kindly change RAM if u have 2 chips try one at a time
5 Suggested Answers
  • 135 Answers
SOURCE: motherboard drivers
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N32-SLI%20Deluxe
find drivers here
Posted on Jan 18, 2009
  • 1602 Answers
SOURCE: Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
THIS MAY BE THREE WAYS ONE IS THREW THE BOIS
AND
JUMPERS ON THE MOTHERBOARD
VEDIO CARD
AND
SOFTWARE DRIVEN FOR THE MOTHERBOARD AND VEDIO CARD
THE MONITOR TOO [DRIVERS]
PROPERTIES, ADVANCE SETTINGS
IF YOU NEED MORE INFO PLEASE CONTACT THREW THE WEB SITE
ROD
Posted on Feb 05, 2009
MPetro302
  • 298 Answers
SOURCE: "A8n32-sli deluxe" SATA support disapeared
call or visit ASUS support forums, you may need to RMA this board.
Posted on Aug 10, 2009
  • 240 Answers
SOURCE: cannot detect ide1 and ide2 even bios setting set
Many times this problem is due to incorrect cable connections. Check your manual for correct cable connections of devices to IDE1 and IDE2. More than one drive may be connected to each cable but master devices for each channel must be connected in a certain manner on each cable.
Posted on Dec 03, 2009
SOURCE: ACPI\PNPB006 for A8N32-SLI DELUXE Windows-7
disable MIDI and GAME port in BIOS:
Power up PC, Press DELETE to go in BIOS
Go to Onboard Device Configuration
Posted on Oct 10, 2010
Feb 20, 2010 | Computers & Internet
What games does my philips controller work on
how 2 get the drivers p4vmm2 multimedia audio controller
Sep 04, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Aug 09, 2009 | AMD ASUS A8N32-SLI Deluxe Socket 939...
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Screen does not work
Make sure your video card is fully secured down if it is and you still have the same issue check and make sure for compatibility otherwise you video card is cooked.
Mar 19, 2009 | ASUS A8N32-SLI Deluxe Motherboard
A8N32 BSOD PROBLEM
I had a similar problem with this board after putting in a new sata drive I got Bsod as windows xp started loading.
There is some kind of conflict with SP3, Sata and usb.
The solution for me was to boot while having a 4GB usb drive pugged in. It starts up fine now. If I remove the usb drive it bsod´s again.
Dec 14, 2008 | ASUS A8N32-SLI Deluxe Motherboard
A8N32-sli stops at the post
start fresh. take off or disconnect. modems, cd-dvd drives,etc. just have the minimum to run and start from there.Make sure that the CPU and memory (try just 1 stick) is installed correctly,and tightly. If that doesnt work send it back..
Jun 10, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Blue screen in A8N32 SLI Deluxe Motherboard which worked excellently-ACPI
I had this issue myself. It took a very long day of searching... but all I ended up having to do was disabling the parallel port in BIOS. (I even went so far as to update BIOS, and the bugger just wouldn't load past the Windows loading screen unless I turned off that stupid parallel port.
I know this solution is late, but maybe it could help.
Mar 10, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Motherboard not starting Bios but fans start
Yes, had exactly the same problem earlier this week, the bios chip may be faulty, as you know all other components work, so it's down to the motherboard and a replacement is required
Mar 22, 2007 | ASUS A8N32-SLI Deluxe Motherboard
AMD ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce4 SLI X16 ( Sold Out) (ASA8N32) Motherboard Logo
66 people viewed this question
Top AMD Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
