Question about Brother HL-2040 Laser Printer
Toner and Paper problem..
After I changed my toner the "Paper" light comes up.. When I take out the new toner the light disappear.. also.. when i try to print the paper get stuck.. Please help us to solve this problem..=]
    Scholar:
  • 161 Answers
Obvious you have some restriction in your printer somewhere. a small paper lodged in your printer. Clean it well rolling the rollers checking the gears to see if something small has gottin lodged somewhere. Be care to place the toner right back into position as it was removed. It must fit snug and be in line perfectly.
Posted on Aug 06, 2007
Canon MFC-9150c Printing repeat down right side of paper only. Everything in center and on left prints fine. Tried a new toner, and visually inspected inside of machine. The repeat is very faint, but is...
You will need to replace the fuser. What has happended is the hot roller has lost its teflon coating and this is allowing the toner to stick to it, therefore the stuck toner is repeating do the edge of the paper until it disappears. A new fuser will cure it. It is user fittable to. You must have the power off when you change it. There is no reset for it just change it and power up and all will be fine.
May 09, 2011 | Office Equipment & Supplies
How do you change a toner cartridge
Open up front op panel,mid door opens up tube sitting on top of drum unit is the toner cart! be care full can get messy!Pull lever on end of tube (will only go 1 way from original position)lift up and dispose of.pull white tape off of new cart install in drum push lever,open and close mid door a couple of times to cycle toner toner message will disappear.
Nov 23, 2010 | OKIFAX 4580 Plain Paper LED Fax
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
ctnozil
Victorman
Victorman
