Question about Technics SL-BD22 Turntable
Technics S.L. turntable tone arm lifter does nothing, at the end of the record the needle stays down and scratches record back to start.
The arm will not lift or go down by it self
5 Suggested Answers
JSPCEXPRESS
  • 178 Answers
SOURCE: tone arm is hard to move
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Posted on Feb 13, 2008
  • 133 Answers
SOURCE: technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Posted on Sep 23, 2009
gokomets
  • 120 Answers
SOURCE: TECHNICS SL 1910 TURNTABLE SERVICE
The grease and lube in the mechanism will
need cleaned out and replaced due to the
"age" of table! The "lifter" may be bound
up due to grease drying out...
Posted on Apr 17, 2010
Deneenie
  • 73 Answers
SOURCE: I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Posted on Feb 22, 2012
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
Feb 20, 2012 | Technics Audio Players & Recorders
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
Technics sl 1200 MK2 WEAK SOUND
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Needle Skates
If you're a real DJ then the Technics is the best TT to scratch on. Don't listen to that fool about not scratching, lol. Your tone arm could be the problem. Have it checked out. I repair TT's
Mar 18, 2009 | Technics SL-1210 Turntable
I have a technics 1200 mk2 turntable. It turns on properly, and appears to work, but when I place the needle on the record, I get nothing through the speakers. I don't know if the connection is being...
Turntable signal problems are difficult to locate because of the extremely low signal levels. Are you sure that you have the output of the turntable connected to a Phono input? If connected to a standard AUX or Tape input, you won't hear anything. Check for signal by turning on the unit and touching lightly the needle. You should hear a scratching sound. If not, start with a new needle.
Keep us posted.
Dan
Aug 14, 2008 | Technics Audio Players & Recorders
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
Feb 13, 2008 | Technics SL-1200 Turntable
Technics SL-BD22 Turntable Logo
41 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
