Question about Whirlpool Washing Machines
The tub will not spin in the rinse cycle
The tub on my whirlpool washer will not spin in the rinse cycle.
  • steve
    steve May 11, 2010
    The tub does not spin in the rinse cycle. It agitates in the rinse cycle.
    It spins in the spin cycle.
  • 478 Answers
This sounds like a timer problem if it will spin in other cycles. If you hear a motor running but no spin it is the motor couple.
Posted on Mar 13, 2009
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
The washer off and on on the rinse and spin
there prob coins blocking drain pipe and cant 100% empty.
i had it with mine
Apr 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
Jan 19, 2010 | Kenmore Washing Machines
When washer goes into the rinse cycle it won't fill it contue to try and fill but won't
Check your manual. Some washers don't fill when they rinse, instead, they spray rinse. While the tub spins, they spray water in every few seconds until the cycle is completed. This is also how the second rinse works on a lot of models.
Dec 01, 2009 | Whirlpool Washing Machines
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
