Sc300 ricoh please how can i fix code sc300 from my ricoh oficio c3500
2 Suggested Answers
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Error sc300 on Ricoh mpc 7500. i replaced the drum unit and its fine but after two weeks the error came up again
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
Aug 26, 2016 | Ricoh Aficio Office Equipment & Supplies
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
I have ricoh mpc6000 there is error code 300 how to solve
SC300 D Drum charge corona wire error: K
The output of the charge corona wire of the black PCU is abnormal. • CGB power pack connection loose, broken defective
• BCU defective
• Replace OPC drum More likely needs a new Charge assy. or Charge grid. Roughly $20-$100 for part(s).
Apr 29, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Error Code sc300-01
Replace Charge corona end blocks
Dec 12, 2013 | Ricoh Aficio Office Equipment & Supplies
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
Como soluciono el error sc300 de la ricoh 2060SP
sc300 on a Ricoh 2060 is a corona wire error. Typically what happens is the corona wire has snapped, and a new wire needs to be installed.
May 28, 2010 | Ricoh Aficio AP3800C Laser Printer
RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
May 25, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 service call
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Feb 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
k24674
jasbo
jasbo
