Question about Mitsubishi WS-55805 55" Rear Projection Television
Model# ws-55805 mitsubishi tv HD
I had got this tv yesterday from a client of mine. He said that he was having a problem with it so instead of getting it fixed he purchased another one. The problem he said he was having with it was, the same I am facing. That problem is that you get three colors that are like shadows of one another, It almost looks like a 3D and it is also kind of curved looking as well. Is there anything I can do to fix this issue, and any idea if i can replace any part myself? Do you have any idea how much it will cost to repair? I am pretty good at alot of things, mabee I can repair this myself if I knew what the problem is. Thank you in advance for any information and help you could offer. By the way the TV was made in 2000.
  • kylepjp Nov 19, 2007
    i am having a new similar problem with mine, but only with the blue lamp. I'm guessing from what I've read my convergence board is going out. Is there anything i can do to stop it? If not, can i still get parts for a year 2000 ws-55805 such as a convergence board
  • solluna Apr 24, 2008
    I have problem with the color, showing like shadows green and red. I try to converge resetting to the factory no luck, still the same Please help me. I call sears repair center The technician told me is 2 IC have to be changed but the parts is only $ 56.00 and the labor is about $ 315.00 I do not want to pay that kind of money. Please advise me what to do. Thanks, Miriam
I had the exact same problem. I read the posts - jiggled the large heat sinc and saw the instant improvement of the convergence - intermittently - (the most helpful posts by FFJim and MikeNJ1964 thank you!). I then got a copy of the repair manual (online) and isolated the two Convergence Power Chips IC8D01 and IC8D02 according to the repair manual and are parts HIC-STK392-040). I was able to use an alternate way to get to the cold solder joints (broken solder points) on the bottom of the entire motherboard (all three boards) assembly (without removing the middle board) by removing many of the cables (9 or so) and leaving just the tube cables in the back right corner connecting the RGB complex. After removing the cables, and unscrewing the 3 wood screws holding down the plastic (black) housing holding the main boards, I was able to slide out, lift and twist the motherboard assembly on it's side while leaving the RGB complex cables at their location. Looking at the bottom of the motherboard assembly (inspecting all the solder joints) I found the area of cold solder connections for the STK392-040 by seeing where the two Mitsubishi WS-55805 IC8D01 and IC8D02 solder points were located. It appears the reason these solder points get loose is becaus of the large Heat Sinc they are connected to would heat up, lean and will break loose with movement of the TV. By just re-soldering the cold broken lead points (which were visible) it repaired my unit entirely. This can be done at home with just a simple solder iron and solder (make sure you heat the lead and solder pad and apply the solder to the hot area (not the iron). I had to do that to about 6 of the 30 or so leads. Then, I retraced my steps assembling the unit and it worked great!
Here is an image of my main board assembly from the manual.model# ws-55805 mitsubishi tv HD - 0da1d36.jpg
Posted on Jul 11, 2008
  • 398 Answers
When the 3 colors no longer line up and the sides are all curved, the convergence circuits have stopped working. Usually the convergence output IC has shorted out and has overloaded the convergence power supply which stops working. The output IC (usually STK393-110)should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I make a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Posted on Aug 05, 2007
  • gd3141 Mar 26, 2011
    THANKS MAN ,I FIX MINE LAST NIGHT.2 PINS ON THE POWER BOARD AND THE CONVERGENCE BOARD.WERE NEVER SOLDER.AT ALL.DON'T KNOW HOW IT LASTED THAT LONG. 60 IN MODELM2000.WAS GOING TO JUNK IT.I SAID OK GIVE IT A TRY.WOW IT WORKED.I WAS THINKING THAT WONT FIX IT.I DID.GREAT.PICTURE LOOK GREAT.
    GLENN. THANKS ALL
    New Friend:
I soldered the cold solder joints; didn't fix it. Then I replaced IC8D01 and IC8D02; didn't fix it. All resistors looked good. Then I noticed that F9A23 (5A) was open on the pcb next to the convergence pcb. It was standing up with a .22 ohm resistor connected in series. I replaced the fuse and that fixed it! I suspect that the original ICs were okay only needing the cold solder connections soldered and the fuse replaced.model# ws-55805 mitsubishi tv HD - 12_24_2012_2_38_13_pm.jpg
Posted on Dec 24, 2012
I fixed mine today! I found solder was not making a good connection on the convergence board ( middle green board ). If you pull off the back cover, there are three boards. Carefully remove the center board, there are several screws and plugs. You will have to remove the three bolts holding the large heat sink in, the two pieces that sit against that board had a bad connection at a few of the pins. I took the board to a local electric store ( Mayfair Electronics ) and they soldered the connections for $30.00. Works great now!!!
Note! If you want to make sure that is the problem before tearing your tv apart. While the tv is acting up put some slight pressure on the large heat sink by pulling or pushing and see if your picture straightens out.
Posted on Nov 20, 2007
ONLY HD picture does not fit on WS-55805
To be kind you are wasting your time, This is a 1st generation HD set not designed for the modern equipment you are using---You cannot turn a Model A Ford into a Roll Royce.
I has only one HD input designed for a set top HD box providing it a 1080 I signal.
Dec 04, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
Mar 03, 2010 | Televison & Video
Mitsubishi hd 1080
What about the cable input? Does it work?
Sep 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Never hooked up the HD
Have you tried selecting a different input( do you have the remote?), if so have you set your input to accept HD input ( you access this thru your 'Menu" button on your remote). I run my HD input from my game console (X-Box 360) and have to select HDTV input channel (there are 2 of them along with 2 cable inputs), and have not had a problem with this at all. good luck.
Mar 18, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Turns off
No I do not have an answer yet
May 19, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi projection HD
how long after you replaced the chips has it been working?
did you check the resisters?
did you check to see if you have bad caps?
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Parts and repair
go to www.ptscorp.com and send the board in
Dec 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Display
OPTION MENU "MENU 1270" SERVICE MENU "MENU 1257" CONVERGENCE MENU "MENU 1259, 4 FINE, 5 COARSE, 6 MISC
Sep 15, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
1,569 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
