Question about Dryers
Hunter 44155c programmable thermostat - a/c will not turn off
I am replacing a venstar p474-1050 thermostat with a hunter 44155c. the venstar (from left to right) has the following wiring codes R - G - Y1 - W2 - BOW1 - Y2 - C the wires are colored (as they are in the venstar) Red -Green - Yellow - white - orange - brown the hunter is labeled(from left to right) G - RC - RH - Y/O - W/B - Y1 what is the correct way for me to wire this please
SOURCE: 3 Month baby and need help hooking up thermostat ASAP
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Posted on Jan 28, 2009
buffalonyman
  • 1865 Answers
SOURCE: ground wire
The ground wire needs to be attached to the dryer frame, either screw will work
Posted on Apr 16, 2009
Greg20
  • 149 Answers
SOURCE: What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Posted on Jun 22, 2009
heatman101
  • 43501 Answers
SOURCE: im replacing my honeywell with a hunter 44110 the
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 05, 2009
kingbrizzle
  • 407 Answers
SOURCE: Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Posted on Jan 23, 2010
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44155C Thermostat
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
Jan 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dryers Logo
66 people viewed this question
Top Dryers Experts
