Question about Water Filters & Coolers
Homestyles water cooler myl1035s - Water Filters & Coolers
Homestyles MYL1035S water coller not cooling water. Is this worth repairing or should it be replace?
Posted on Jun 13, 2013
My sewing machine is not working. It quit a year ago. Model # F08-702-H-01. I don't know whats wrong. I was told it might be the foot pedal?? Where can I Find one for this machine
So, I was able to figure out it is a Homestyles machine? Please provide the symptoms. Does the light work? Is it frozen--the handwheel won't turn, does it stitch okay (even if operated manually), is the tension off, does it break thread? Give us some clues.
http://www.fixya.com/tags/homestyles/sewing_machines
Mar 14, 2017 | Sewing Machines
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
HomeStyles water cooler. How can I make the water temperature cooler?
Check to see if there is a thermostat on the back that can be adjusted with a screw driver, if not it is probably factory set and not adjustable or it is one of those electronic modles without a compressor, there may be a way to set them with instructions in your owners manual. (but probably not)
Aug 04, 2014 | Water Filters & Coolers
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
Does the water cooler actually use electricity overnight when it is still plugged in to the mains but not in use ?
Yes, the water cooler does keep a small amount of water cold all the time...so it will run periodically even if you are not using water...
heatman101
Aug 14, 2010 | Hamilton Beach Water Cooler with Storage...
West Bend Homestyle Bread Maker Manual
Go to the parent company website www.focuselectrics.com and pick company and product. Under replacement parts for your model number their will be a manual you can download.
Oct 05, 2008 | West Bend 41077 Just For Dinner¿...
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Water Filters & Coolers Logo
1,021 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
