4190sm 2 zone expander
Honeywell how to
You don't say what kind of control panel you're trying to add this to, but I would guess a Vista 20 based on the symptoms. You cannot use a 4208U for this panel...what you need is a 4219, but even that may not work because Honeywell has changed the components without changing the part numbers, making the new expanders incompatible with older controls. You may need to upgrade to a Vista 20P.
Aug 26, 2014 | Ademco 4208u Universal 8 Zone Remote Point...
Honeywell Strat RTH9580 reboots continuously when connected to Taco ZVC406 transformer
Might be a load that's too heavy for your stat. Consider installing an isolation relay.
Feb 18, 2014 | Taco Zvc406-exp-4 Boiler Zone Control,6...
DSC LCD5511 System troulbe nr. 1
system trouble can mean that you might have a faulty expander somewhere. an expander is used to extend the zones on your current system. if not you might have a faulty pacife connected to the system go around all the pacifes and check if the red light comes on. if not replace it.
Jul 08, 2013 | DSC LCD5511 Sixtyfour Zone Fixed Message...
Cant see the message in the inbox while we are chatting
Try to follow these few steps, & you should be okay =)
1) Go to "Run". You can click the start bar, then type "run" in the search bar, the application should pop-up right after that.
2) In the "Run" interface, type "regedit", & a window says "Registry Editor" should come out after that.
3) Okay, now pay attention because this is where we get the tricks done. In the "Registry Editor" panel, look for "HKEY_CURRENT_USER". Expand it.
4) From there (expanded HKEY_CURRENT_USER) & now on, expand all the way according to these order: --> Software --> Microsoft --> Windows --> CurrentVersion --> Internet Settings --> Zones.
5) In "Zones", there should be consist ONLY with "0,1,2,3,4" accordingly. Anything besides those numbers, DELETE it. Close the "Registry Editor".
6) Now you can try opening your YM. & tadaaaa!... It's back to normal.
Jun 08, 2011 | Yahoo Messenger
I can't see anything anyone types to me in the IM box and once I hit send I can't see what I sent. I have done everything yahoo instructed me to do, clean out my cache, uninstalled and reinstalled...
Jun 03, 2011 | Yahoo Messenger
In yahoo messenger in chat window sent or received messages are not seen...i tried downloading JAVA again and messenger also installed again after removing cache but nothing works...I am using windows 7 32...
I can not see messages sent or received on yahoo messenger, though i can see what i am writing but once i press enter, there is nothing on top half of the screen. Also the person to whom I send messages...
Why my yahoo messanger didnt show a message from my message box my operating system is windows xp plss help thx !!!!!!
Try to follow these few steps, & you should be okay ( do some restore point 1st in case system went wrong after altering procedures ) :
Jun 02, 2011 | Yahoo Messenger
Text not appear
5) In "Zones", there should be consist ONLY with "0,1,2,3,4" accordingly. Anything besides those numbers, DELETE it. Close the "Registry Editor". Done!
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
