Question about Pioneer Avic-z110bt, Avicz110bt, Avic-z110 Usb Cable
Black and white vertical lines on screen, then black
Make sure the unit is not full of dust.... when it gets hot the video goes screwy...
Apr 18, 2014 | LG Office Equipment & Supplies
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
Jan 08, 2010 | LG 42PC3DV 42 in. Plasma EDTV
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
No Picture On Screen
change the 33uf 35v at the vertical filter
Thans!
Mar 10, 2009 | Televison & Video
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Pioneer Avic-z110bt, Avicz110bt, Avic-z110 Usb Cable Logo
20 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
