Question about Toshiba Office Equipment & Supplies
How to reset the bulb timer for TOSHIBA TLP-XD2000
I replace the bulb currently and turn the unit ON. it giving me the on/standby light (RED)...
User Manual said I need to reset the timer but the manual have NO instruction How to reset the bulb timer.
Please Help
  • sdahlin Apr 28, 2009
    I have the exact same problem. How do you reset the lamp timer. Can I choose reset all from another menu?
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Posted on Aug 27, 2010
  • jljesusn
    jljesusn Dec 16, 2012
    wheres the answer?
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 13, 2010 | Sharp (AN-XR10LP) Projector Lamp for XR10X
Recently I was using my xv-z90u, I started the projector up and turned it off right away and the bulb replacement lights started flashing and going into a standby mode(two red lights). So I replaced the...
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Jan 14, 2010 | Sharp Projector lamp Projector Lamp
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Toshiba lcd projectors tlp xc 2500
Verify "Key Lock" function is not enabled
Jun 14, 2009 | Toshiba Replacement Projector Bulb...
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
2,314 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Richard Roth
Richard Roth
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
