Question about SanDisk 4GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter
Targus adapter how do I download my pics to my macbook pro?
Macbook adapter A1184 stopped charging
Things break. Get a replacement on ebay. eBayeBay
Jul 28, 2012 | Apple MacBook Pro Notebook
Windows 7 driver for Targus ACB10US1
your driver can be downloaded by using this pro tool: Driver Update Software for XP Vista 7 8. Have a nice day
Mike
Feb 02, 2012 | Targus USB Bluetooth Adapter (ACB10US1)...
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | Targus Portable USB Notebook Mouse &...
My laptop has suddenly frozen, i turned it off by the power button and whenever i try to turn it on it turns white screen, then shutsoff after 3-5minutes.
Resolution
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter, learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
Also:
The MacBook SMC Firmware Update v1.1 improves the MacBook's internal monitoring system and addresses issues with unexpected shutdowns. This update is recommended for all MacBook systems, including those that received warranty repair.
You can use the Software Update feature of System Preferences, or download the MacBook SMC Firmware Update v1.1 from Apple Software Downloads.
Note: If your MacBook is running Mac OS X 10.4.6, you won't be able to see the SMC Update until you update to Mac OS X 10.4.8. Once you have updated your system software, the SMC Update will appear as an option in Software Updates.
MacBooks running Mac OS X 10.4.7 will be able to download and install the SMC Update, so it is not essential that you update your system software, although Apple always recommends updating to the latest version of the system software.
If your MacBook is in a state where it will not remain on long enough to install the update, wait for the issue to reproduce itself. Once the MacBook has turned itself off, turn the computer on by holding the power button down. Keep the button down until you hear a single long tone. Once you hear the tone you can release the button, install the recommended updates, and restart normally.
Dec 30, 2010 | Apple MacBook Mac Notebook
Need drivers for a Targus; download via site doesn't complete installation.
http://www.targus.com/us/drivers_manuals.asp?SKU=ACB10US
go to this web site and download IT the driver and installed it
Jun 02, 2009 | Targus (ACB10US) Bluetooth Wireless...
Need drivers for a targus bluetooth supplied cd doesnt work nor does anything i download. running vista home premium x64
Try to download the vista drivers from the link below.
http://www.targus.com/us/Downloads/ACB10_V6_0_1_6300_Vista_only.exe
May 27, 2009 | Targus (ACB10US) Bluetooth Wireless...
Bluetooth not found error message
http://www.targus.com/us/Downloads/ACB20_UG.pdf.
Hello, here are instruction for installing your adapter. Hope this helps
Mar 20, 2008 | Targus 328 Feet USB-Bluetooth Adapter...
SanDisk 4GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
