Question about Dishwashers
Bosch dishwasher sgs4002au/20
Shorting out when switched on
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
Apr 21, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Determine age of Bosch dishwasher
This is the FD number eg
9001
add 20 to first two numbers 110, ignore the first number this is 2010, the last two numbers is the month 01=jan
8804 would be 88+20 108...2008 april
If you can't work it out please comment with FD
May 28, 2013 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwasher trips out as soon as switched on
Sounds like you have a dead short, perhaps in the motor.
Please do not attempt to start it as it might catch fire.
Someone needs to pull it out form the counter and find out the problem for you.
Sorry!
Be Blessed.
Jan 28, 2013 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch sgs53c12 dishwasher and the water light keeps comming on after about 20 seconds into a programme. I have switched it off and on, reset it and checked the inlet hose where it connects to the...
Hello- Bosch installed an anti-flood device in bottom of unit. If water gets into this area ( from a leak, usually). To get water out, tip backwards, then forward. Use a couple of towels- water should come out. Common problem with these units. Let me know if this info helps- have more if needed.- Thanks- Ed
Mar 12, 2010 | Bosch 24 in. SGS43C12 Classixx...
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch SHU3036UC not filling with water
u need more info first what happens when u shut the door and start a cycle
Nov 05, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
