Question about Olympus FL-50 TTL Flash
Flash not working
Nothing..............tried everything..batteries and remotes all fine.................... Is there a fuse
  • Patrick Burke Aug 05, 2007
    San Francisco Daly City......?....
    It has an unusual screw size...? And No that did not solve the problem..(mode +light)....I would like to open it up.....?..
  • 944 Answers
Here is the link to the user manual if you need it; http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf Check page 62 and see if the reset will work; "Press the MODE and LIGHT buttons simultaneously for 2 or more seconds to reset the custom setups to the default settings." Also see if you get any change from cleaning the battery contacts carefully with a cotton bud/Q-tip with a little gin - sometimes a small amount of invisible dirt on these can stop the battery contacting. If you fancy opening the flash up, then if there is a fuse you will be able to see it - there is no easy to swap fuse that can be accessed from the outside. check if anything else inside is obviously burnt or broken - post back a photo if you can and we may see something to check. I think something fatal but probably replaceable has happened in the control electronics - possibly the screen has died. Check if the cable connecting the screen to the main board inside has come loose. Check the connections at the hinges - they can occasionally get damaged or pulled loose. If you don't wish to take it apart yourself; Technical Support (USA) 24/7 online automated help: http://www.olympusamerica.com/E1 Phone customer : Tel.1-800-260-1625 (Toll-free) from 8 am to 10 pm (Monday to Friday) ET E-Mail : e-slrpro@olympusamerica.com See what they have to say. If you want us to try and find you a local repair facility - please post back with your general area. Hope this helps :)
Posted on Aug 04, 2007
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
My Porsche Key fob no longer unlocks the doors
Insert key into door barrel or ignition lock and turn key, whilst doing this press the unlock/lock button, the led on the dash should flash to indicate this has initialised the key to the car, then remove key and test operation of remote. If this fails then a new remote plus coding to the car by your dealership is needed
Feb 16, 2010 | 2005 Porsche 911
My remote door locks dont work with the remote
hi,problem with remote key,you check the battery of the transmitter,fine,how about trying with spare key,or check fuse or send to dealer for proper diagnose,preventing wrong part replacement.
Feb 19, 2009 | 1994 Mercedes-Benz S-Class
Radio CD not working & lights don't flash remote keylock
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
Feb 15, 2009 | 2004 Dodge Caravan
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
Olympus FL-50 TTL Flash Logo
178 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
