Question about Audio Technica ATH-ANC7B Headphones
Take apart headphones
When the noise cancelling switch is on if its tapped at all it will crackle or it will sound distorted until I tap on it a few times
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: My Audio-Technica AT4033CL mic worked
The most common problem at these cases is a loose of the phantom power. Take a closer look at all the connections and check that the phantom power supply voltage is enabled at the mixer. If it's possible check with a multimeter that you have 48V DC at the 2 - e pins of the XLR connector.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Feb 12, 2011
My dell pc fan make a loud noice
There are 13 possible noise on hardware issues
1) Power supply crackling sound
2) Fan sound that sounds like a motor noise dragging
3) Harddisk clicking sound
4) CD rom spinning sound
5) Modem noise pinging sound
6) Application software resident in memory
7) Technician Neighbour drilling holes from your ceiling to do
special wirings late at night, installing transformers
8) Ceiling fan with unstable modified electricity makes noise
on motor issue
9) Sound that comes from switchboxes and transformer
upstairs lighting up free electricity from your fan wires
in your apartment unknown to you tapped by upstairs
residents
10) Voltage regulator malfunction noise issue
11) Monitor crackling sound issue
12) Wirings crackling sound issues
13) Power socket crackling sound issues
Be sure you know where the source comes from, call PC vendor if you are uncertain, you will have to dismantle your
hardware device in vendor's place to find out. Vendor will test one by one.
If computer fan is your issue, it is just a small issue
there are many replacement at PC vendors based on quality
corresponding to the price you pay
Nov 01, 2012 | Computers & Internet
I have an audio technica ath-anc7b noise canceling headphone. There is a crackling sound when I tap lightly on the left hand side of the earphone. There may be something loose. How can I open the cas
I was researching a similar answer and discovered that the left side ear piece actually is actually held together with 3 torx screws that are visible upon removing the ear pad and the padding surrounding the driver. I haven't had a chance to attempt a fix yet but remove those screws and see if you can open the ear piece.
Oct 06, 2012 | Audio Technica ATH-ANC7B Headphones
Sennheiser HD 205 crackle when listening to music
If the crackling occurs only when opening windows or another program, the crackling is not due to the headphones but to a lack of CPU resources in your computer settings.
If you are in Windows 7,
  1. click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then click Control Panel. In the search box, type Performance Information and Tools, and then, in the list of results, click Performance Information and Tools.
  2. Click Adjust visual effects. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Visual Effects tab, click Adjust for best performance, and then click OK.
May 23, 2012 | Sennheiser HD 205 Professional Headphones
Left side is quieter than right side and when pushed on makes crackling noises and sound gets louder
most likely cable is very loosely contacting the jack or earpad. Will need to be taken apart and soldered.
Nov 13, 2010 | Pioneer HDJ-1000 Professional Headphones
My reciever volume cuts in and out and crackles when adjusting
You can CLEAN / LUBRICATEthe volume control know with a CONTACT/CONTROL cleaner, I use a product from Radio Shack, this works wonders on drum type electo mechanical devices which are basically volume control knobs, easy to do, just remove the round knob and spray into the openings with the small tube attached, and rotate in both directions, be sure to unplug the unit first, on a few occasions it is best to remove the front panel to acheive better coverage to the rheostat type volume body, anyway it always cures the crackling and distorting sound, I would give this a try before replacing the part.
Feb 14, 2009 | Technics Audio Players & Recorders
Pioneer VSX-36TX popping and crackling during warm-up period
I have the exact same amplifier with what sounds like the exact same problem. I opened up the amplifier, and while it was powered on started tapping around until I heard the popping and crackling suddenly increase. I was using a piece of wood and the plastic part of a screw driver for this. The popping and crackling suddenly burst out onto all channels when I was tapping on the DSP board (encased in a metal enclosure to the very right of the amplifier).
I took off the metal enclosure (with the receiver turned off, of course :), and with the receiver on, and started tapping around the DSP board, and I found that the biggest crackling effect was achieved when I tapped on the Cirrus Logic CS493292-CL chip which does all the decoding and switching.
I detached and took out the DSP board and looked at it very carefully but of course couldn't find any bad connections. I tried resoldering all the feet of the Cirrus Logic chip and many many components all around to no avail.
Finally I tried applying pressure to the chip while the popping was going on, and it stopped. Further investigation revealed that bending the board around the chip produced the same effect.
For the life of me I couldn't figure out why bending the board eliminates the problem, but my solution was to put a piece of eraser wrapped in masking tape and taped to the Cirrus Logic chip, and two other pieces on the back of the board in such a way that when the metal enclosure was replaced onto the board, it put gentle but firm pressure onto the Cirrus Logic chip and at the same time bent the DSP board slightly.
It's been a few days without popping, clicking or static, but time will tell. Good luck!
Oct 31, 2008 | Pioneer VSX-36TX
Audio Technica ATH-ANC7B Headphones Logo
118 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
