Question about GE Dishwashers
I am working on a GSD5630D00ww that has no wiring schematic or trouble code sheet. It is not draining the water. I have found were not getting power from the timer, but don't know were to go from there
  • GE Master
  • 3,361 Answers
If there is no power from the timer and other functions work. The timer is your problem.
Your model number does not come up on GE service or any other of my sources.
Posted on Mar 12, 2009
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
Hello.
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10026:22372:US&item=8938
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
http://waterheatertimer.org/images/Combination-switch-outlet-6.jpg
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
Washer will not spin . also get an f1 trouble code
The codes for your machine and diagnostics can be found on your machine's Tech sheetb2e8bd3.jpg31389af.jpg12fb88a.jpg
Jul 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 "QuietPak" Washer 7 years old. The water does not enter come the tub; instead there is a buzzing noise and then lighted panel reads a flashing "H" followed by a flashing "F".
Your water valves could be faulty or no power to the valves to open them to allow water flow. You can test power to them with a voltmeter. if there is power, the valves are probably bad. If not power, trace the wires to the source, probably control board.
Apr 01, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Oct 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
FL ERROR CODE - Machine is about 5-6 yrs. old.
I just had this issue two days ago. You have to take the back off the machine. If you have water then drain manually. I did this by taking the drain hose, pulling through the housing, unclipping the hose from the inside of the machine. This will get the hose to ground level, and using a bucket dip the hose down to fill, and up to drain into a bucket. This was time consuming, but it did almost fully drain. I then tipped the washer on its front, and took the bottom cover off. You will see two hoses, going to the pump motor. Remove the hoses, and you will have access to the pump impeller. I removed the entire pump and motor to clean it out. If you do this be careful. I had to find the wiring diagram to reconnect the wires. After pulling out a draw string from a swimming suit, and putting the machine back together it all worked. The repair sheet for this machine is taped to the front panel of the machine. This has all error codes, diagnostic modes, and anything else you will need to know to fix this machine. To get to the sheet, pry off the whirlpool emblem with a flat head screw driver. Remove the screw and lift up the top cover just enough to get the sheet. The sheet is in a plastic bag attached to front panel on your left as you are looking at the machine. Good Luck with the repair. Also check the actual drain hose for a clog. I found a piece of a sock in mine.
Jul 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
F24
take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck
Oct 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Error code for kenmore elite he2 plus
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. Also when you take the cover off you will see a white drain that is covered. Turn it counter-clockwise and remove it - but be prepared with towels because this is the lint catcher and there will be water in it. Clean it out and use a flash light to look up the hose area - I found a lot of loose change in mine.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
70 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
