Question about HP Compaq dx2200 PC Desktop
The fan in my tower sometimes runs loudly and for a long time
My computer is on about 8 hours a day and the fan runs loudly and for long periods of time.
  • 76 Answers
May need to be cleaned if that doesnt work
Replace the fan it sounds like its getting old
Posted on Mar 12, 2009
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
Loud racing noise from the tower e 3052
Open up the side of the tower and you will be able to see the fans. You most likely have dust/hair in one of your fans or one of the fans is going bad. You can clean it out with a low pressure air nozzle or dust can.
May 29, 2009 | E-Machines eMachines Desktop PC
Why does my computer suddenly shut down during use?
remove the side panel and have a look if your cpu fan is turning.... you may need to blow the dust and dirt out of it as well... if the tower even feels remotely warm that's likely the issue... also check the fan on the power supply. either way it will likely need to be cleaned
Robert
Jan 13, 2009 | Computers & Internet
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Loud noises coming from power supply fan?
it might be the fan of your cpu has dust.and making it the fan hard to spindle.if you can dismantle your cpu fan or the fan in your power supply.just clean it with the paint brush.or do it with vaccum cleaner.if you have air compressor the would be better.just blow out the dust.then if you can do it also just putting oil or grease inside the fan at the core.the one that has magnet.it will smoothen the spindling.ok good luck
Dec 03, 2007 | HP Pavilion 505n (DC470A#ABA) PC Desktop
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
HP Compaq dx2200 PC Desktop Logo
1,102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
