Question about HP Photosmart 7850 InkJet Printer
Communication What is next? I have uninstalled and installed software. Changed the USB cable. Checked the USB outlet. Tried my memory card from my KODAK camera, which PRINTS GREAT!! I am thinking it is the USB connection on my printer. What do I do?
  • 47 Answers
My printer is doing the same thing...i've noticed that if you pull up ******* the usb cable (printer side) the computer will recognize it but not print. i'm currently dismanteling it to try to securely fasten the connectors
a-nanny-mouse
Posted on Apr 08, 2008
I HAVE A PHOTOSMART HP 7850. I PUT THE DISK IN AND WANT TO PRINT A PAGE OF ALL PHOTOS TKEN. THE MACHINE STARTING TAKING PAPER AND THEN STOPPED, RED LIGHT STARTED FLASHING. WHAT DO I HAVEW TO DO TO CORRECT?
Posted on Dec 14, 2007
  • Anonymous Dec 14, 2007
    I TRIED TO DO A INDEX ON MY BROTHERS MFC420CN AND WHEN PRINTING EVERYTHING IS RED. HOW DO I GET THE RED OUT?
    Scholar:
  • 161 Answers
Make sure all the drivers have been installed in the control panel of your computer. Let the computer search for an additional driver if it will. Unplug the USB while all is on and give it some time to see if it installs something more. You may have to restart your computer several times with the device USB unplugged and then with everything on plug it back in and see if the computer will recognize it again.
Posted on Aug 06, 2007
SOURCE:
PROBLEM WITH DIGITAL CONCEPTS SIM CARD READER CR-75P
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.A memory card reader is a handy device and are inexpensive.You can copy photos from other cameras and you can also download photos offyour memory card to someone else's computer without the need of installing anyprograms.
Apr 28, 2012 | Cameras
During installation, device is not detected error appears. tried uninstalling software, unplugging cables, restarting, reinstalling, then plugging cables in. did not work. Windows XP o/s. already checked...
is it wireless or usb, if it usb, dont connect the usb cable. on the installation window where it asks for the usb cable, chek mark on the option connect printer later and continue with the installation
Oct 02, 2009 | HP PhotoSmart 7760 InkJet Printer
Its not working as it says it should on the package
try with usb cable check your usb cable is working fine aslo uninstall all usb driver then install again go to my computer property then hardware then device maanger then you see usb drivers uninstall all then just restart computer it automatic install all usb driver.
ten check in my computer yourt meory card is found as removable disk or not.
if not then reattch memory card to it.
Jul 11, 2009 | SanDisk 2GB microSD Memory Card
Epson RX580 Communication Error During Install
Hey...
I ran into a similar problem (okay, the same problem), and my problem turned out to be my USB cable. I was using an extender. When I ran the cable to the PC without the cable extender, my problems disappeared. If you're not using an extender, you might just try a different USB cable.
Hope that helps...
-Buzz
Dec 23, 2008 | Epson Stylus RX580 InkJet Photo Printer
Communication error
uninstall the software.
procedure must be follow. otherwise it will not work.
first. turn off the printer. unplugged fromt the wall.
1). install the software with printer disconnected.
2). turnoff the printer and connect the cable to the computer.
3). turn on the printer.
if you are using USB. makse sure the USB is working.
Oct 19, 2008 | Dell 924 All-in-One InkJet Printer
IXUS 80 can you help...photos won't download.."COMMUNICATION ERROR"
This can be due to various reasons
1)The driver is corrupted: The camera's drivermay be corrupted. Uninstall the driver and any software and then connect the camera to the PC and then re-install the software.
OR
2)The USB cable might be faulty. Remove the memory card from the cam and try using a USB card reader(You can get one for 5$) and see if works. If it does may be then its time to buy a new USB cable for your cam.
3)Last but not least the cam's firware may been corrupted. Its pretty easy to flash the firmware so we can try it. Let me know if the above solutions worked or not so that we can try the firmware update
Oct 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
No communication
From the Lexmark web site:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct driver for your model and OS.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected. Search the KnowledgeBase
Jun 14, 2008 | Lexmark X1240 All-In-One InkJet Printer
Cannot get PDA Smartphone to sync with computer
software you need to install software
let it install before connecting phone to comp
then after finish the install then connect the phone to usb cable
you might if this didnt work the first time have to uninstall all the software and try a fresh copy of the software in comp to sync everything with desktop manager
May 29, 2008 | Dopod 838 Smartphone
HP Photosmart 7850 InkJet Printer Logo
128 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
