Question about Brother IntelliFax-2820 Laser Fax
Cannot receive or send faxes
It rings but fax journal says bad connection/out of memory
Can't receive incoming faxes. but able to send faxes
Posted on Mar 20, 2009
  • 62 Answers
See user manual for setting ring sensitivity. This may be where your problem is. Hope this information was helpful!
Posted on Mar 13, 2009
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
I have a panasonic fax machine. It will receive
if this is to every line then you have a bad main board or your ringer waiting period needs to be increased... (meaning the amount of times it rings before pickup...
Dec 10, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot send or receive faxes
This problem might be the moden board, or main board, or both.
Oct 13, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Journal memory
Yes, press
Function
61
set
You will get a Journal Print
Oct 02, 2009 | Panasonic PANAFAX UF-6000 Fax
Retrieving old fax transmissions
Usually the journal only holds the last 50 sends / receptions.
Feb 02, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
Jan 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Customer not receiving all faxes
I tend to agree that if it was a bad modem that any of the faxes would get out at all. You might try stepping down the max xmit rate. Did you try to manually dial the problem number? Did the person on the other end hear the fax ring or see any activity about trying to connect? What did the transmission report say? Any info will help.
May 03, 2007 | Panasonic PanaFax UF-8000 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
182 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
