Question about LGDVT418 System
I have no sound when plaing radio ones i turn on system.
When turning ON the system all I get is a AIR nois and then it dies out like it needs to charge.
    Problem Solver:
  • 5 Answers
I don't have this particular system but that problem sounds familiar. When i've run into this problem, i noticed that i had pressed the function button one too many times and so just as the radio channel came on, it slowly faded out and the system changed to its next function which was the dvd player. First make sure the fm antenna, or am loop, is connected properly and there are no bare wires exposed or touching anything metallic.
Posted on Mar 12, 2009
What's wrong with my car?
Sounds a lot like an alternator issue; flickering can occur if a diode fails in the regulator, allowing the DC voltage to fluctuate. Also, when that happened the alternator probably stopped charging the battery and the battery discharged down to the point where when you tried to turn on the A/C, there wasn't enough current left to activate the A/C clutch and the vehicle died. Have the charging system checked out. The battery, if drained and if older, may also need to be replaced. If lucky it might only need recharging.
Nov 02, 2016 | Cars & Trucks
My stereo will turn on with pwr/volume button, the dim light behind it will also turn on, but its missing the digits, no display, and no sound. What could it be?
Sorry, your radio has died.. I can fix them, but I don't. Cheaper for you to get a new after market one. If you have an amp, bypass it or replace it also.
Oct 16, 2016 | 1991 Lexus LS 400
The car was being driven and died. It turns over but wont start, and doesn't go into gear. Windows quite working and radio and clock don't come on. Buzzing sound from air bag mode.
Sounds like a power supply issue. Make sure the battery is fully charged and the charging system is working properly. If the ECM senses low battery voltage it will shut down different parts of the electrical system in order to maintain a constant power supply for the necessary electronics
Jun 30, 2015 | 1996 Mercury Grand Marquis
Chevy Avalanche radio turns on but no sound comes out of speakers at all. Whats the problem??
Radio Amp has died. Replace the Radio. The Amp/Pre Amp is built into the radio if this is stock. Buy a new one and install it.
Jun 28, 2010 | 2004 Chevrolet Avalanche
HOWLING NOIS ONLY ONE RIHGT TURN COMING FROM LEFT
sounds like a wheel bearin if turn to one side or the other, jack it up and see if any play in wheel from top to bottom
Mar 22, 2010 | 2003 Dodge Durango
1996 Jeep Cherokee Sport won't start
sounds like you need a new altenator
Jul 01, 2009 | 1996 Jeep Cherokee
Electrical Starter/Power windows 1999 jetta GLS 2.0 manual
this nois is the sound of the starter solenoid that trying to close the contacts so the starter energizes and crank your engine . because it not recieving the sufficient power so its cant close the contacts , thats because dead , loose , damaged baterry cables . in your case check your battery cabkes if not there is a problem with your ignition system
May 31, 2009 | 1999 Volkswagen Jetta
Battery and Air conditioner will not work in Infiniti G35
my radio ad a/c works only same times for ten minute and then turn off and no works maybe until next day
Apr 01, 2009 | 2005 Infiniti G35
LGDVT418 System Logo
117 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
