Question about Asko Dryers
Thumping sound in my asko dryer
Thumping sound
Rotu
  • 175 Answers
SOURCE: ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Posted on Mar 25, 2007
  • 135 Answers
SOURCE: Our Asko dryer (T720) has
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Posted on Aug 02, 2008
abhishek33
  • 1239 Answers
SOURCE: Asko T720 clothes dryer -
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Posted on Sep 13, 2008
  • 28 Answers
SOURCE: Asko T720 Dryer with a wobbly, thumping drum.
you probaly have problems with rollers in front of the drum.
Posted on Jul 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My Asko dryer is thumping
You need to have your drum rollers replaced, they are making the noise because they are falling apart.
Also it could be or include the drum belt breaking down and falling apart...which means its about to break.
Normally pretty cheap parts can be found on the net...look around.
Its a pretty easy fix.
Posted on Jan 15, 2011
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
Asko T711 Dryer
Most often the top panel is the first to be removed, a couple screws in the back and then lift and slide forward. That normally gives access to view how the rest of the puzzle went together.I changed bearings on my Crosley and never did move the front cover. This might give you a place to start while waiting for a better answer.
Jan 06, 2014 | Asko Dryers
My Asko dryer is thumping loudly. I am finding bits of rubber when the lower panel is removed.
Jan 15, 2011 | Asko Dryers
When operating dryer makes LOUD thumping noise. Is this fixable?
this sounds like rotator wheel(s) are broken. It is some what an easy fix. The drum dyer needs to rotate those wheels. Usually you need two.
Jan 05, 2011 | Asko T741 Dryers
Rythmic thumping sound
probably the rear bearing or the drum shaft
Nov 15, 2008 | Asko T701 Electric Dryer
Asko T720 clothes dryer - thumping noise like the drum is damaged and shakes when going.
hi
Sep 13, 2008 | Asko Dryers
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Aug 01, 2008 | Asko Dryers
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Open Questions:
Dryers Logo
18 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
