Question about Gateway MX6920 Notebook
Faint Graphics on Screen
17" MX6920
Boots ok. Can see faint image on screen. Can see boot information
for a few seconds and Windows XP LOGO for a few seconds.
Tried it on CTR with the same effects.
Can see & change bios information.
  • rlp_1 Mar 12, 2009
    The Post/Bois is normal. The Laptop is pluged in with New adapter.
  • rlp_1 Mar 30, 2009
    Thanks for the help u guys rock!!
  • 916 Answers
Please so a repair installation with the xp disc
Load windows with the cd then do not press r when prompted on the bottom
When shown the partitions choose the xp partition then press R
Posted on Mar 30, 2009
  • machadojr_fe Mar 30, 2009
    Is everything fain even the BIOS and the logo?
    If so you need a new back light. Once replaced the problem will be resolved
    Brigadier General:
  • 3,614 Answers
try to adjust the screen resolution, also the brightness on the BIOS settings
Posted on Mar 12, 2009
  • 408 Answers
If you are running off of battery or ac adapter, this sounds to me like an issue with the power options.  Got to your control panel, click on power option.  Go to advanced and there you can turn your brightness up.  laptops go into this mode to conserve power.  More annoying than anything.
WINDOWS TRIES TO LOAD , THEN SCREEN GOES BLANK.
Try booting to safe Mode (f8), see if you get a normal screen that does not shut off. If you do, then suspect a graphics driver update (usually caused by windows update) that is incompatible with your laptop. Solution is to uninstall the graphics driver and re-install one from the the dell support / downloads website for the OS that you are using.
If it will not boot even in safe mode, try connecting it to an external monitor, if it boots ok on there, you can eliminate graphics chip problems and look at the possibility that it may be the inverter failing or the backlight in the screen.
To give rough indication, if the screen image can be seen in a dark room albeit very faintly, it is the backlight that is the problem, if there is no image at all, suspect the inverter, both are located behind the screen bezel.
If the screen refuses to boot into life on an external monitor, you have a problem with the graphics chip on the motherboard
Jul 27, 2011 | Dell Inspiron 6000 Notebook
My laptop boots up but the screen is blacl
Try connecting the laptop to an external monitor first. If this works, you can eliminate the Graphics chip as a source of your problems.
If it fails to work on an external, the graphics chip on the motherboard has possibly gone bad.
If it does work, you have 3 possible problems:
  • The VGA cable has been damaged (unlikely)
  • The inverter has gone, you can check this by seeing if you can see a faint image on the screen in a darkened room, if you cannot, probably the inverter is at fault and will need replaced
  • The backlight has gone on the screen, if you CAN see a faint image, then the screen is getting power but the lamps are not lighting, you will need to replace the screen of the laptop.
Jul 20, 2011 | Acer Computers & Internet
ASUS A2S machine boots but screen is blank. has POST sound.
Offer some light to the screen as...it might just be the inverter if you lucky look really closely at the screen close up and see if you can see a faint image...
Or even better still try and connect it to a external monitor and see if it boots up properly..if it does then it looks like the inverter..or a lose wire from the motherboard to the screen.
Cheap enough on ebay,and easy to replace,..
If it doesn,t post on a external monitor,it may be a issue with the graphics card...if so..then google your make and model and see if the graphics card is onboard or a separate card...if its separate then it can be replaced quite easy if you have the experience..
If it,s onboard then you will have to take it to some1 who can maybe reflow that part of the board as it may be a weak solder joint,or replace the graphics chip
Hope this helps....if so please rate this,and if i can be anymore help..
Regards
Apr 02, 2011 | ASUS Computers & Internet
Display Shows on External Monitor, but very faint
one of two causes : inverter board damage ( Replace it) or backlight lamp damager (also replace it).
May 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Screen image very faint (almost gone)
Hi
could you plz give me the model num of the product?
i want to go and find you a diagram or some sort of image about this so you can check if it all looks the same and if you did damage something else on the product...
What you also can do is send me a pic of both screens witht hte contact points so i can go look it up for you????
What happends when you adjust the Clarity or brightness on the screen???
Kind regards
SlitWrists
May 13, 2009 | Acer Computers & Internet
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen not working.
If there's an external image, here's the possibilities:
Bad inverter (25-30.00)
Bad backlight in lcd (new lcd 75.00-100.00)
THe cable has been disconnected from the lcd or the motherboard.
That's really all it can be. Is there any image, no matter how faint, on the lcd? If so, I'd go for a new inverter.
Good luck, hope it helps.
Nov 26, 2007 | Lenovo ThinkPad T30 PC Notebook
Gateway MX6920 Notebook Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
