Question about Whirlpool Calypso GVW9959K Top Load Washer
Repair manual Where I can download the repair manual for the Whirlpool Calypso GVW9959KQ1. Thanks for your Help.
Https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Posted on Jan 31, 2008
    Novelist:
  • 135 Answers
Somebody stated in a consumer product review that he found a repair manual mounted inside the front panel of the machine. He also gives some details of repair work that he did to his washer, so you may want to read the review for yourself. Link below: --> http://www.dealtime.com/xPR-Whirlpool-GVW9959K~RD-380361477764
Posted on Aug 04, 2007
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't Run
Download the repair manual for this machine. You will need it to assist you in the repair of this style washer. These are involved machines when it comes to repair and the manual is going to be your best help at this point.
Thanks
Jan 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error on washing machine
sounds like you have a bad motor controller board. there is a fuse on this board it's directly behind the consol on the left side. check the fuse if it is bad you know that is what your problem is.
Jan 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer model #GVW9959KQ1 and its flashing CA. I bought this from a second party so I don't have a manual. What does that code mean? Where can I get a manual for this washer? Thank you,...
either that or you have a bad u joint causeing an overcurrent situation. check at the board first. make sure that you use he detergent because the regualr soap leaves a nasty build up.
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Machine - Thanks you for your Response Posting!
the class action lawsuit comprised of people who still owned their units and needed repair. what whirlpool would do is send a repair technician out on their own, they would get a list of parts for the washer and replace them when the parts came in. i own a calypso and my u joint went out and whirlpool repaired it free of charge over a 400.00 due bill to them. was just good that it never came out of my pocket. however ive since learned how to fix my unit. bt i havent had any issues with mine since the u joint and pump were replaced. i replaced the pump myself and other tuff rquired a special tool. im not sure if they are giving compensation on the washer but its worth a call to whirlpool.
Nov 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is leaking
check the boot hasnt split in the door well
Nov 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
2,125 people viewed this question
Sal De
Marvin
Marvin
jimorris77
